Warning: A/R is not interfaced with General Ledger
On the same screen, you need to set the default journal code before you can change anything in company config. You will need to go to the journal first and make sure you have a non-system journal to set. General Journal is best…
So steps are, Journal code maintenance, select general journal and make this a non-system journal. Then, set the default journal to the general journal. Then check the interface check boxes
