Eric, if you mean to exclude closed PO lines and/or releases -- then yes you
can.
Using Crystal Reports, format all the fields that appear in the PO line
section (headings and details) with the Suppress attribute formula similar
to this:
if {podetail.OPENLINE} then No Else Yes
Also, change all the related PO Line Sections to Suppress Blank Sections
This should exclude closed lines.
Good luck
Jim Stetter
Sent: Tuesday, August 01, 2000 12:58 PM
To: Vantage@Egroups. Com
Subject: [Vantage] When printing P.O.'s is it possible to exclude closed
lines?
Is it possible to exclude closed receiving lines when reprinting P.O.Â’s?
Eric Tolliver
Continental Industries Inc.
5456 E. Mcdowell Rd.
Mesa, Az 85215
http://ciirelays.com/
mailto:e.tolliver@...
can.
to this:
Good luck
Jim Stetter
lines?
Eric Tolliver
Mesa, Az 85215
