Where can I find the FixBinsAllUILog created from Refresh PartBin QOH?
I’m trying to correct some SOH qty discrepancies and have successfully run the Refresh PartBin QOH From PartTran process. It tells me I can review the results in the FixBinsALLUILog.log file. It doesn’t give me the menu tree structure where that file is located and for the life of me I can’t find it. We’re on-prem and have separate servers for SQL and Kinetic server software. I can’t see it on my client pc (I’ve run a search of C: drive). I recall something in the past (pre-Kinetic) about storing “stuff” like this out on the client (or was it server) under Epicor Users > [user id] but my memory may be fuzzy and/or Kinetic has gone an entirely different route. Any suggestions on where I can narrow down my search???
So you should be able to go to server file download in the menu tree.
User “Server file download” as mentioned by Devin or there should be a shared folder on your app server to see the same files.
Ok, my IT compatriot was able to locate the file. The issue is on my part in that I don’t have access to navigate to the server where the log file was located.
I jumped the gun on this one. Call it operator error, award me a couple of "AW #*(&,s) and ignore this posting.
I ran into the same issue - here’s some additional details. For my on-premise installation the log file saves on the Kinetic application server at:
installationDrive\EpicorData\Companies<Company Name>\Log<username><File Name>.log
