For Windows Vista or 7 64-bit clients, run odbcad32.exe under C:\Windows\SysWOW64 to access the 32-bit ODBC Data Source Administrator. Hope this helps.
--- In vantage@yahoogroups.com, "pklein256" <pklein@...> wrote:
> Contact Epicor For installing ODBC if you need help. the ODBC runs in 32 bit. Their instructions are pretty straight forward and I've also seen some other comments on this group
> --- In vantage@yahoogroups.com, "gracefulthreads" <gracefulthreads@> wrote:
> > Gerry,
> > I have 8 engineers plus myself running Vista 8.03.406A on Windows 7 x64 with no problems at all. The normal install went without a hitch. Our only issue is ODBC for 64-bit, which I just haven't gotten around to installing yet (probably in the next few weeks). The Crystal run-time also installed properly and everything is just ducky.
> > Ernie Lowell
> > Senior Operations LLC - Sterling Machine
> > --- In vantage@yahoogroups.com, Gerry Mauricio - Gmail <gerrymauricio@> wrote:
> > > Has anybody had any success trying to use Windows 7 workstations with
> > > Vantage 8.03?
> > > We're getting ready to upgrade/replace our older workstations, and we
> > > really don't want to downgrade new machines to WinXP.
> > > Let me know your thoughts. Thanks.
> > > Gerry Mauricio
> > > Klune Industries
> > > 7323 Coldwater Canyon Ave.
> > > North Hollywood, CA 91605
> > > Gerry Mauricio - Gmail Account
