Writing BPM on sales order picklist
That was my thought though I had not read anywhere that method BPMs can only be attached to BO dlls. Anyway, I did a VB customization that calls a external progress .p file. There are some posts floating around on the board on how to do it. But it was pretty straight forward and appears to be working.
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> I don't think you can do a BPM, because the method is Epicor.mfg.RPT.., not
> Epicor.mfg.BO..
> I think you'd have to put a customization at the UI level, and somehow
> capture the click of the print or print preview, and call the appropriate
> adapters. However, it is possible that the adapters won't work from within
> the print parameter screen (for example, I can't get the adapters to work
> from within a dashboard customization).
> If all else fails, do you have Service Connect? Perhaps in the UI, you
> could write a text file out that Service Connect would pick up and process.
> Kevin Simon
> SimsTrak Consulting
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> tchristie1
> Sent: Thursday, September 22, 2011 7:00 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Writing BPM on sales order picklist
> Has anyone found a solution for this?
> I am comfortable in both BPMs and VB.net customizations but I can't seem to
> find a way to get it working. In our case the particular functionality I
> would like is complicated but all stems from getting a bpm to trigger when
> the printer sends the print request to the server. I can do the rest once I
> can do that.
> The method called according to the trace is:
> Businessobject: Epicor.mfg.rpt.sopicklistreport
> Methodname:SubmitToAgent
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> advantage@ wrote:
> > Picklist print from Menu
> > Sent from my Verizon Wireless BlackBerry
> > -----Original Message-----
> > From: "Dan Sirow" <dansirow@>
> > Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Date: Thu, 10 Feb 2011 16:53:00
> > To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
> > Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > How are you printing? Autopprint, Picklist print in Menu...?
> advantage@ wrote:
> > > Let me be more specific
> > > Much like Job Entry when a Job Traveler gets printed it stamps the Job
> as printed
> > > When printing the Sales Order Picklist the Get List pulls SEVERAL orders
> on the Sales Order Picklist. When this function happens I'm trying to figure
> out how a BPM or Customization would stamp the sales order as printed
> > > I've done many BPMs but not from Print Parameter screens
> > > From: advantage@
> > > Date: Wed, 9 Feb 2011 20:09:42
> > > Subject: [Vantage] Writing BPM on sales order picklist
> > > Can you write a bpm that marks what orders got printed on Sales Order
> Pick List
Can you write a bpm that marks what orders got printed on Sales Order Pick List
Much like Job Entry when a Job Traveler gets printed it stamps the Job as printed
When printing the Sales Order Picklist the Get List pulls SEVERAL orders on the Sales Order Picklist. When this function happens I'm trying to figure out how a BPM or Customization would stamp the sales order as printed
To: <vantage@yahoogroups.com>
> From: advantage@...
> From: advantage@...
I am comfortable in both BPMs and VB.net customizations but I can't seem to find a way to get it working. In our case the particular functionality I would like is complicated but all stems from getting a bpm to trigger when the printer sends the print request to the server. I can do the rest once I can do that.
> From: "Dan Sirow" <dansirow@...>
> > From: advantage@
Epicor.mfg.BO..
Kevin Simon
SimsTrak Consulting
tchristie1
can do that.
as printed
> > From: advantage@
Pick List
