We are receiving the following error when trying to print out a job traveler in our Pilot System:
Program Ice.Services.Lib.RunTask when executing task 5046928 raised an unexpected exception with the following message: RunTask:
System.IndexOutOfRangeException: SysRowID
at System.Data.ProviderBase.BasicFieldNameLookup.GetOrdinal(String fieldName)
at System.Data.SqlClient.SqlDataReader.GetOrdinal(String name)
at System.Data.SqlClient.SqlDataReader.get_Item(String name)
at Ice.Core.RptBase.OutputRelationDataWriter.WriteRowsForKeyValues(IDataReader reader, IList`1 keyParameters, IDataSource relatedTable, Object[] keyValues) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 112
at Ice.Core.RptBase.OutputRelationDataWriter.WriteRowsForKeyValues(IDbCommand sqlCommand, IList`1 keyParameters, IDataSource relatedTable, Object[] keyValues) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 84
at Ice.Core.RptBase.OutputRelationDataWriter.WriteRows(IDbCommand sqlCommand, IList`1 keyParameters, IDataSource relatedTable, UniqueKeyCollection relationKeys) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 165
at Ice.Core.RptBase.OutputRelationDataWriter.WriteTable(DataSourceRelationship relationship, IDataSource relatedTable, DataColumnCollection keyColumns, UniqueKeyCollection keyValues) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 190
at Ice.Core.RptBase.OutputRelationDataWriter.WriteTables() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 44
at Ice.Core.RptBase.ReportDataBuilderBase.WriteOutputRelationshipTables() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDataBuilderBase.cs:line 262
at Ice.Core.RptBase.ReportDataBuilderBase.XMLClose() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDataBuilderBase.cs:line 211
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 89
at Ice.Core.RptTaskBase`1.XMLClose() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 229
at Erp.Internal.JC.JobTrav.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ERP\ERP11.2.400.0\Source\Server\Internal\JC\JobTrav\JobTrav.cs:line 579
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 78
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_releases\ICE\ICE4.2.400.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 69
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_releases\ICE\ICE4.2.400.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 60
at Ice.Hosting.TaskCaller.ExecuteTask(IceDataContext dataContext, Boolean suppressTransaction) in C:\_releases\ICE\ICE4.2.400.3\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 40
at Ice.Services.Lib.RunTaskSvc.<>c__DisplayClass30_2.<InnerRunTask>b__1() in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Services\Lib\RunTask\RunTask.cs:line 460
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 57
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_releases\ICE\ICE4.2.400.0FW\Source\Server\Services\Lib\RunTask\RunTask.cs:line 457
I believe this is being caused because the dataset for the standard SSRS now has a “PrintAttributes” report parameter. The old SSRS dataset did not. Also, the SysRowID field needs to be unexcluded from the RDD
If I print a standard job traveler this comes out fine. However, this means that all of our custom reporting is now in question because of an added parameter.
Is anyone else having this issue with their custom reports? If so is there a better way to handle these issues going forward?
