Patrick
(Patrick Winter)
December 17, 2024, 9:01pm
1
I have had 5 users today get the Kinetic Home Screen Box with the spinner with Kinetic Hanging up while loading the home page.
The fix is looking under Windows Updates and seeing the 2024-12 Cumulative Update for Windows 11 Version 24H2…
After running the windows update Kinetic starts working again.
Wow thanks for posting this, we are having the same problem but thought it was just us. We have been doing reinstalls all day.
Don
(Vito Signorelli)
December 17, 2024, 9:38pm
4
We also found a temporary fix that involves deleting the cache located here…
C:\ProgramData\Epicor
Sorry to ask, just Client or browser too?
Don
(Vito Signorelli)
December 17, 2024, 9:47pm
6
No Issues from the browser, we were also using that as a fall back.
Patrick
(Patrick Winter)
December 17, 2024, 9:51pm
7
Browser’s works with Edge and Chrome.
This was what we have been doing also and are seeing a lot of hung tasks and sessions in Epicor. Ending those and deleting the cache folder has resolved ours
Randy
(Randy Stulce)
December 17, 2024, 9:59pm
9
I created a batch file that kills any running sessions, clears the cache then opens Epicor
// Kill all Epicor and EpiEOBrowser processes
taskkill /f /im epicor.exe
taskkill /f /im EpiEOBrowser.exe
// Delete entire directory tree including root Epicor folder at each directory (logs and cache)
rmdir /s /q %appdata%\epicor
rmdir /s /q %localappdata%\Epicor
rmdir /s /q %programdata%\Epicor
// Launch Epicor via existing shortcut
start "" "C:\(path)\Epicor\Epicor.lnk"
Don
(Vito Signorelli)
December 17, 2024, 10:00pm
10
Sweet, thank you! Will definitely be giving this out tomorrow.
aosemwengie1
(Alisa Osemwengie)
December 17, 2024, 10:09pm
11
We have been clearing the cache too but most of them only fixed with reinstall.
Patrick
(Patrick Winter)
December 18, 2024, 3:53pm
12
Day 3 since upgrade to 2024.2, now users that were originally fixed, get the same hung session and need client cache cleared to get going again.
OFMChris
(Chris Means)
December 18, 2024, 3:57pm
13
These steps from Epicor Support worked for a few of our users this morning.
On the affected workstations, please perform the steps below to delete the Epicor client cache.
Close the client
From Windows, Open File Explorer
Navigate to C:\ProgramData\Epicor
Note: ProgramData is a hidden folder and you’ll need to click on the View option to check the hidden items.
Here you will find a folder named after your server, with a port number appended to it, (e.g. servername.domain-808)
Delete this folder, sub-folders and files
NOTE: these folders will get recreated again when the user logs into the client
Log into the client and follow up with the results.
aosemwengie1
(Alisa Osemwengie)
December 18, 2024, 4:00pm
14
Same. Over and over again.
Patrick
(Patrick Winter)
December 18, 2024, 4:07pm
15
Also loading task manager and killing the epicor sessions.
Monitoring Session Management because we are using up user licenses due to repeated attempts.
Randy
(Randy Stulce)
December 18, 2024, 4:08pm
16
Us too I created a old school batch file I noted above and added it as a shortcut to users’ desktops. They know now to run that when they get this issue. It’s a stop gap but allows our users to function.
Patrick
(Patrick Winter)
December 18, 2024, 4:15pm
17
I’m starting to roll out your batch file. Thx
Noffie
(Adam Nofsinger)
December 27, 2024, 8:35pm
18
Has anyone reported this to Epicor? Is there a case?
Randy
(Randy Stulce)
December 27, 2024, 8:39pm
19
Yes and Epicor has already pushed a fix too (for SaaS) and likely a hotfix for on-prem.
