Thad,
I recall that in 3.0 everyone saw everyone's else's favorites in Item Maintenance, but you could only edit your own items. It was rather tricky to find your own Items at times. There is a table in Vantage that stores all that stuff, so doing a quick report to list it all out helps in gaining some organization over it. Although we never had the strange behaviour that you are describing, I remember trying to unravel things for people whose shortcuts changed -- especially shortcuts to outside programs rather than Vantage Menu items. In 5.0 it becomes a bit more intuitive in that you only see your own Items in Item Maintenance.
The two tables in Vantage that hold this info (in 5.1 at least) are FavItems and FavFolder.
Troy
Troy
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Monday, June 24, 2002 1:46 PM
Subject: [Vantage] 3.0 Favorites Bar Issues
A user switched machines and her favorites bar is no longer working. You
can add items to the bar, but when you click on the item, nothing happens.
The user says that "Vantage deleted all her favorites", while she was trying
to remove the broken links.
So I tried to recreate the error, and lo and behold, when I login as myself
on my workstation, any new shortcut I create is non-functional, though all
existing shortcuts still work.
When attempting to delete shortcut for part tracker, the shortcut for the
job tracker gets deleted instead.... In Item maintenance, there are many
duplicate entries, which would lead me to believe that it is showing all
user's items (without showing a user name).
A test on another client, logged in with another user name yields similar
results.
Has anyone had similar isssues with the 3.0 favorites bar and were those
issues sucessfully resolved before upgrading? Were those issues
automatically resolved upon upgrade?
Thanks in Advance,
Thaddeus Jacobs
Information Solutions Developer
Kinematic Automation, Inc.
mailto:tjacobs@...
