4th attempt installation of vantage 50 (i am so fru strated)
For the Error in startup of database localhost:20931:epic50. Message:
12:13:53 BROKER:**This process terminated with exit code 1. (8619), look at
http://www.progress.com/services/support/cgi-bin/techweb-kbase.cgi/webkb.htm
l?kbid=19939
<http://www.progress.com/services/support/cgi-bin/techweb-kbase.cgi/webkb.ht
ml?kbid=19939&keywords=8619> &keywords=8619
This appears to be an improper setting with the after-image writer, if this
is any indication of what the problem really is.
For the SERVER: Unable to create shared memory
sharemem.g.epic50.vantage.db.vantage 5, error 1455 (1719) error message,
look at
l?kbid=19522
ml?kbid=19522&keywords=1719> &keywords=1719
From reading through these and some other stuff on the Progress web site, it
look like you might have some type of configuration error with you -N or -Mn
parameters.
Hope this helps,
Ted Kitch
ted@...
Sent: Wednesday, April 04, 2001 10:12 AM
Subject: [Vantage] 4TH ATTEMPT INSTALLATION OF VANTAGE 50 (I AM SO
FRUSTRATED)
Ok, I think I am about ready to EXPLODE!!!!!!!!!!, I need to know if anyone
has this types of problems before. This is my 4th attempt of installing
vantage 5.0 with a walked through installation of a vantage helpdesk
person.
Problems
1. Schema changes was running for 10 hours and crashed.
2. Schema changes was running for 14-16 hours and crashed. (a month later)
3. A tech support came down here and tried fixing the problem but
unfortunately he didn't have any luck either and I was told that there is
nothing wrong with our database and 1 thing that added to our problem is the
application error dr. Watson. ( 2-3 weeks later)
4. This time they fixed schema changes problem and application problem,
however we got a new problem now. shared memory error. " SERVER: Unable to
create shared memory sharemem.g.epic50.vantage.db.vantage 5, error 1455
(1719) and another error. " Error in startup of database
localhost:20931:epic50. Message: 12:13:53 BROKER:**This process terminated
with exit code 1. (8619).
We made sure that everything was turned off opened services and turned most
of the application off except for progress 91A, doubled the size of virtual
memory and we have a lot of HD space but they still can't help me. I called
progress helpdesk person but they haven't been able to help me as well and I
feel like a ball that's been passing around. Vantage claimed it's our server
but how come we are able to run vantage 4.0 and not vantage 5? Last
conversation I had with vantage help desk person was He's gonna have me run
progress90B with vantage 5.0. Isn't this CRAZY OR WHAT??? THIS IS DRIVING ME
NUTZ and it's making me LOOK BAD TO MY BOSS AND TO MY CO WORKERS. I AM SO
FRUSTRATED!!!!! HELP! HELP! HELP! GAWD HELP ME! :-(
WHAT'S NEXT?!?
Marites Marlar
MIS Department
SPS Non-Ferrous
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=162801.1342250.2934640.1280005/D=egroupmail/S=1700007
183:N/A=599088/*http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer
t_ComputersInternet_Software_WhiteGridTime&t=ad> Click Here to Find Software
Faster
Click Here to Find Software Faster
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Marites,
I would suggest that you try an installation on another machine to determine
whether the problem really is specific to the server. You need to set
boundaries on the possible error sources. As it stands you don't really know
whether it's the system, OS, database or application.
John
Sent: Wednesday, April 04, 2001 11:12 AM
FRUSTRATED)
person.
Problems
WHAT'S NEXT?!?
Marites Marlar
MIS Department
SPS Non-Ferrous
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
