[6.1] Customer Required Specs on POs to Our Vendors
If the verbage is the same for all PN's of a customer you wouldn't
want to maintain it on a PN by PN basis anyway. Bite the bullet and
jump into ODBC. I'm using it a ton and haven't had issues since
moving to the SQL92 version.
Brian
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> Might work too but probably not here. A quick RB check shows our
Part Descs now vary from 1 to 271 char in length. PartDesc is a X
(1000) memo field so would choke CR and we can't trim it to 255
(withou changing the long ones now in use). As it is we have a
number of descriptions over 150 characters which does not leave much
to work with. If I could truncate the descriptions to 255 I would
probably prefix the specs section with a "marker" string (like [S])
and search for that as a variable starting point but this opens a can
or worms everywhere else needing to have the description chopped off
where we don't want the specs to show (invoices, etc...).
> -Todd C.
> -----Original Message-----
> From: Shirley Graver [mailto:shirleyg@R...]
> Sent: Friday, September 02, 2005 11:21 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: [6.1] Customer Required Specs on POs to
Our Vendors
> Here's another Idea, determine a max size you use for your part
description
> (say 35 characters) The as Lydia suggested, put your specs in the
extended
> part description. Then created a calculated field using MID(
string, 35,
> 255). This would pull out the next 220 characters of description
into its
> own field that you can place anywhere on your form.
> Shirley
> _____
Behalf Of
> Lydia Coffman
> Sent: Friday, September 02, 2005 11:27 AM
> To: 'vantage@yahoogroups.com'
Our
> Vendors
> Just a thought here -- what about the extended description of the
part?
> Are you already using that for something else? Seems like you
could open
> that description up on the PO (to 5 lines or whatever)and truncate
it if
> there is nothing in there.
> Might be worth a try.
> Lydia
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Friday, September 02, 2005 8:19 AM
> Subject: [Vantage] Re: [6.1] Customer Required Specs on POs to Our
> Vendors
> Todd,
> Couldn't you enter the verbage in the Customer VB form field and
add
> a subreport with JobProd, OrderHed, and Customer tables? The
> subreport would be linked by the Job # in JobProd to the Job# in
> PORel.dbf.
> Brian Stenglein
> Clow Stamping Co.
wrote:
> > They are the same for every part for that customer (part to
> customer is 99% one-for-one relation here as I expect it is for you
> too). Preferable would be to trigger block of specs on PO to our
> vendors for any job related to that customer - for all parts. But
if
> there is a way to code the specs on the parts we can live with that
> as being easier to remember to do than job notes on each job (as we
> are doing now and often forgetting). I was really hoping there was
> some table somewhere that I have been missing that carrys at least
> part specs through to the PO or worst case I can grab with ODBC.
> > Another thought......maybe I will create DBFs with PO print
preview
> and have a distributed report for each customer that has the specs
> bolted in as an .bmp image file the user can maintain with Windows-
> Paint. We only have 5-6 such customers. This would suffice until
we
> eventually get to 8.0.
> > Thanks,
> > -Todd
must have
Builder and
> < http://groups.yahoo.com/group/vantage/files/>
> _____
> YAHOO! GROUPS LINKS
> * Visit your group "vantage <
http://groups.yahoo.com/group/vantage> "
> on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
> < http://docs.yahoo.com/info/terms/> .
> _____
> Tracking #: EDCDCAE343CEA74A83404545F4CC8BDE18E4692E
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> SPONSORED LINKS
> Membership <http://groups.yahoo.com/gads?
t=ms&k=Membership+database+software&w1=Membership+database+software&w2
=Database+mortgage+software&w3=Pda+database+software&w4=Database+manag
ement+software&w5=Database+marketing+software&w6=Online+database+softw
are&c=6&s=190&.sig=zumlzfMugtt6gdHbPv4SEw> database software
Database <http://groups.yahoo.com/gads?
t=ms&k=Database+mortgage+software&w1=Membership+database+software&w2=D
atabase+mortgage+software&w3=Pda+database+software&w4=Database+managem
ent+software&w5=Database+marketing+software&w6=Online+database+softwar
e&c=6&s=190&.sig=gjZta7wG6hZqdrJXzK2Teg> mortgage software Pda
t=ms&k=Pda+database+software&w1=Membership+database+software&w2=Databa
se+mortgage+software&w3=Pda+database+software&w4=Database+management+s
oftware&w5=Database+marketing+software&w6=Online+database+software&c=6
&s=190&.sig=3Hn54KU1wFHab_pC8mcmQw> database software
t=ms&k=Database+management+software&w1=Membership+database+software&w2
are&c=6&s=190&.sig=36Lz5dDq6L3dzupiJwAffg> management software
t=ms&k=Database+marketing+software&w1=Membership+database+software&w2=
Database+mortgage+software&w3=Pda+database+software&w4=Database+manage
ment+software&w5=Database+marketing+software&w6=Online+database+softwa
re&c=6&s=190&.sig=k5h2EoDyGba8G2MtsW5WSQ> marketing software
Online <http://groups.yahoo.com/gads?
t=ms&k=Online+database+software&w1=Membership+database+software&w2=Dat
abase+mortgage+software&w3=Pda+database+software&w4=Database+managemen
t+software&w5=Database+marketing+software&w6=Online+database+software&
c=6&s=190&.sig=-puLLcDG0gUTIJTiT0fjEw> database software
> _____
> YAHOO! GROUPS LINKS
> * Visit your group " vantage
<http://groups.yahoo.com/group/vantage> " on the web.
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
Service <http://docs.yahoo.com/info/terms/> .
> _____
An opportunity to share your unique and creative solutions....
We are increasingly seeing requirements from customers that we include on our POs to vendors (material or subcontract) various specification statements. Mostly for anything military related. These vary by customer with some required for every part for the customer. Our jobs are each exclusively for one customer but POs to vendors are linked only to the job and not the SO so customer is not available to test for. This leaves the inclusion of the specs in job notes up to manual process by falible humans.
Things like:
MIL-STD 1684
PA-2632 II(d)
PA-2632 III
MIL-I-45208 Rev A.AM.1
What we need is as automated a way as possible to get each specific customer's specs requirements (specification number alone is OK as long as we attach the verbage for it) on to the face of the PO. Is there any facility in Vantage to handle this? Or anyone out there who has faced the same need and found an acceptable solution? We could perhaps do it by on the part if necessary if that will work so that every PO related to that part gets the correct specs statements - or gets them into the job's memo that that prints on the PO. All with as little human intervention on each PO as possible. Oh, and I completely reject a monster formula field in the Crystal PO report that tests for each customer and adds text. The system users need to maintain this via Vantage not me via CR developer.
Todd Caughey
Harvey Vogel Mfg. Co.
We're right in there with you. We had a third party create a "subtier
shipping request" form, but you still have to know what you are doing and
for whom. Let us know if you do get this automated.
Sent: Thursday, September 01, 2005 3:35 PM
Subject: [Vantage] [6.1] Customer Required Specs on POs to Our Vendors
Things like:
MIL-STD 1684
PA-2632 II(d)
PA-2632 III
Todd Caughey
SPONSORED LINKS
Membership database software Database mortgage software Pda database
software
Database management software Database marketing software Online
database software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
It would be nice if vantage had the capability to add a specification
just like an ABOM Material item to the Partmaster, but with 0 qty per
usage so it didn't drive requirements in the system. You could maintain
revisions on the spec as well.
_____
Sent: Thursday, September 01, 2005 2:35 PM
by falible humans.
Things like:
MIL-STD 1684
PA-2632 II(d)
PA-2632 III
Todd Caughey
SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Mem
bership+database+software&w2=Database+mortgage+software&w3=Pda+database+
software&w4=Database+management+software&w5=Database+marketing+software&
w6=Online+database+software&c=6&s=190&.sig=zumlzfMugtt6gdHbPv4SEw>
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Membe
rship+database+software&w2=Database+mortgage+software&w3=Pda+database+so
ftware&w4=Database+management+software&w5=Database+marketing+software&w6
=Online+database+software&c=6&s=190&.sig=gjZta7wG6hZqdrJXzK2Teg>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Membership
+database+software&w2=Database+mortgage+software&w3=Pda+database+softwar
e&w4=Database+management+software&w5=Database+marketing+software&w6=Onli
ne+database+software&c=6&s=190&.sig=3Hn54KU1wFHab_pC8mcmQw>
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Mem
w6=Online+database+software&c=6&s=190&.sig=36Lz5dDq6L3dzupiJwAffg>
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Memb
ership+database+software&w2=Database+mortgage+software&w3=Pda+database+s
oftware&w4=Database+management+software&w5=Database+marketing+software&w
6=Online+database+software&c=6&s=190&.sig=k5h2EoDyGba8G2MtsW5WSQ>
Online database software
<http://groups.yahoo.com/gads?t=ms&k=Online+database+software&w1=Members
hip+database+software&w2=Database+mortgage+software&w3=Pda+database+soft
ware&w4=Database+management+software&w5=Database+marketing+software&w6=O
nline+database+software&c=6&s=190&.sig=-puLLcDG0gUTIJTiT0fjEw>
_____
YAHOO! GROUPS LINKS
_____
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the system manager.
This footnote also confirms that this email message has been swept by
MIMEsweeper for the presence of computer viruses.
www.clearswift.com
We have faced something similar recently, but I don't know if this is applicable to your situation.
We have a vender from which we purchase some critical parts. Every PO that goes to this customer must have verbiage on the PO stating to the effect "A singed certification of compliance must accompany each part stating the part meets the specifications required". We accomplished this by adding the statement in the "Comments" for the vendor in Vantage. We then made a very minor change to the POform in CR (adding the pub.vendor table thru ODBC) and then adding the "vendor.comment" field in the lower page header section of the POform. It is only displayed when there is something in the comments for the vendor. Works well for us.
Hope this helps.
Dale Norris
IT Manager
Bullen Ultrasonics Inc.
>>> cmuhlestein@... 9/1/2005 5:15 PM >>>
_____
by falible humans.
Things like:
MIL-STD 1684
PA-2632 II(d)
PA-2632 III
Todd Caughey
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
the system manager.
www.clearswift.com
Yahoo! Groups Links
Todd,
Are the specs the same for every part of a specific customer, or do
they vary by PN?
Brian Stenglein
Clow Stamping Co.
> Things like:
> MIL-STD 1684
> PA-2632 II(d)
> PA-2632 III
> Thanks,
> Todd Caughey
They are the same for every part for that customer (part to customer is 99% one-for-one relation here as I expect it is for you too). Preferable would be to trigger block of specs on PO to our vendors for any job related to that customer - for all parts. But if there is a way to code the specs on the parts we can live with that as being easier to remember to do than job notes on each job (as we are doing now and often forgetting). I was really hoping there was some table somewhere that I have been missing that carrys at least part specs through to the PO or worst case I can grab with ODBC.
Another thought......maybe I will create DBFs with PO print preview and have a distributed report for each customer that has the specs bolted in as an .bmp image file the user can maintain with Windows-Paint. We only have 5-6 such customers. This would suffice until we eventually get to 8.0.
-Todd
Sent: Friday, September 02, 2005 8:49 AM
Subject: [Vantage] Re: [6.1] Customer Required Specs on POs to Our Vendors
Todd,
they vary by PN?
Brian Stenglein
Clow Stamping Co.
> Things like:
> MIL-STD 1684
> PA-2632 II(d)
> PA-2632 III
> Thanks,
> Todd Caughey
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
Todd,
Couldn't you enter the verbage in the Customer VB form field and add
PORel.dbf.
Brian Stenglein
Clow Stamping Co.
> Thanks,
> -Todd
Vendors
> Todd,
> they vary by PN?
> Brian Stenglein
> Clow Stamping Co.
to
not
job
> > Things like:
> > MIL-STD 1684
> > PA-2632 II(d)
> > PA-2632 III
specific
so
statements -
I
to
> > Thanks,
> > Todd Caughey
access. )
> _____
> YAHOO! GROUPS LINKS
> _____
That would work too. The question would be.."to ODBC or to not ODBC". To date no users here have ODBC. Distributed reports though are common. But the writing is on the wall and ODBC will be everywhere soon enough to replace RB so I might go ahead and bite the bullet with this project.
-Todd
Sent: Friday, September 02, 2005 10:19 AM
Todd,
PORel.dbf.
Brian Stenglein
Clow Stamping Co.
> Thanks,
> -Todd
Vendors
> Todd,
> they vary by PN?
> Brian Stenglein
> Clow Stamping Co.
to
not
job
> > Things like:
> > MIL-STD 1684
> > PA-2632 II(d)
> > PA-2632 III
specific
so
statements -
I
to
> > Thanks,
> > Todd Caughey
access. )
> _____
> YAHOO! GROUPS LINKS
< http://groups.yahoo.com/group/vantage> " on the web.
Service < http://docs.yahoo.com/info/terms/> .
> _____
SPONSORED LINKS
Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Membership+database+software&w2=Database+mortgage+software&w3=Pda+database+software&w4=Database+management+software&w5=Database+marketing+software&w6=Online+database+software&c=6&s=190&.sig=zumlzfMugtt6gdHbPv4SEw> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Membership+database+software&w2=Database+mortgage+software&w3=Pda+database+software&w4=Database+management+software&w5=Database+marketing+software&w6=Online+database+software&c=6&s=190&.sig=gjZta7wG6hZqdrJXzK2Teg> mortgage software Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Membership+database+software&w2=Database+mortgage+software&w3=Pda+database+software&w4=Database+management+software&w5=Database+marketing+software&w6=Online+database+software&c=6&s=190&.sig=3Hn54KU1wFHab_pC8mcmQw> database software
Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Membership+database+software&w2=Database+mortgage+software&w3=Pda+database+software&w4=Database+management+software&w5=Database+marketing+software&w6=Online+database+software&c=6&s=190&.sig=36Lz5dDq6L3dzupiJwAffg> management software Database <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Membership+database+software&w2=Database+mortgage+software&w3=Pda+database+software&w4=Database+management+software&w5=Database+marketing+software&w6=Online+database+software&c=6&s=190&.sig=k5h2EoDyGba8G2MtsW5WSQ> marketing software Online <http://groups.yahoo.com/gads?t=ms&k=Online+database+software&w1=Membership+database+software&w2=Database+mortgage+software&w3=Pda+database+software&w4=Database+management+software&w5=Database+marketing+software&w6=Online+database+software&c=6&s=190&.sig=-puLLcDG0gUTIJTiT0fjEw> database software
_____
YAHOO! GROUPS LINKS
_____
Might work too but probably not here. A quick RB check shows our Part Descs now vary from 1 to 271 char in length. PartDesc is a X(1000) memo field so would choke CR and we can't trim it to 255 (withou changing the long ones now in use). As it is we have a number of descriptions over 150 characters which does not leave much to work with. If I could truncate the descriptions to 255 I would probably prefix the specs section with a "marker" string (like [S]) and search for that as a variable starting point but this opens a can or worms everywhere else needing to have the description chopped off where we don't want the specs to show (invoices, etc...).
-Todd C.
Subject: RE: [Vantage] Re: [6.1] Customer Required Specs on POs to Our Vendors
Here's another Idea, determine a max size you use for your part description
(say 35 characters) The as Lydia suggested, put your specs in the extended
part description. Then created a calculated field using MID( string, 35,
255). This would pull out the next 220 characters of description into its
Shirley
_____
Lydia Coffman
Vendors
Just a thought here -- what about the extended description of the part?
Are you already using that for something else? Seems like you could open
that description up on the PO (to 5 lines or whatever)and truncate it if
Lydia
Vendors
Todd,
PORel.dbf.
Brian Stenglein
Clow Stamping Co.
> Thanks,
> -Todd
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage < http://groups.yahoo.com/group/vantage> "
on the web.
_____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
