[6.10.511] Possible bug? Delete PackSlip but leave Line
Todd: don't know if it is a known bug, but if you download the readme file
from the latest patch, you could check for it. I know, you probably already
thought of this. We are on patch 531 (since the end of September) and I
haven't heard a whisper on a problem like this.
Lydia
Sent: Tuesday, December 20, 2005 11:20 AM
Subject: [Vantage] [6.10.511] Possible bug? Delete PackSlip but leave
Line
Ran into an oddity today. Apparently after receiving a subcontract shipment
(and it showed up on "received but not invoiced" report) someone deleted the
packing slip header - without deleting the line. So when invoicing was
attempted it kept saying there was no such PackNum. I ran a quick RB to
select that PackNum and no records were found BUT SubShipDtl did have a
line. I had our A/P person re-add the packing slip header and everything
was then OK - it showed up with the line already there.
This seems like it should not be allowed to delete a header and leave lines
that refer to it. A database no-no in terms of referential integrity.
Anyone know if this is a known bug in 6.1 and if it has been fixed in a
patch sometime after 511?
Todd Caughey
Harvey Vogel Mfg. Co.
Yahoo! Groups Links
Ran into an oddity today. Apparently after receiving a subcontract shipment (and it showed up on "received but not invoiced" report) someone deleted the packing slip header - without deleting the line. So when invoicing was attempted it kept saying there was no such PackNum. I ran a quick RB to select that PackNum and no records were found BUT SubShipDtl did have a line. I had our A/P person re-add the packing slip header and everything was then OK - it showed up with the line already there.
This seems like it should not be allowed to delete a header and leave lines that refer to it. A database no-no in terms of referential integrity.
Anyone know if this is a known bug in 6.1 and if it has been fixed in a patch sometime after 511?
Todd Caughey
