I just received the fix for this for 9.05.701 32-bit SQL, which includes 8 different .r files. I'll get them installed and do some testing and let you know how it works.
Ernie Lowell
Diba Industries
Ernie Lowell
Diba Industries
--- In vantage@yahoogroups.com, "Elizabeth" <gracefulthreads@...> wrote:
> SCR 106098 has been entered on this, with an expected fix in patch 9.05.702. I am reportedly getting a one-off.
> Ernie Lowell
> Diba Industries
> --- In vantage@yahoogroups.com, "redrhyno13" <cwineinger@> wrote:
> > There's a known issue with the Progress version of 905.701 of speed delays. I posted it about a month ago....
> > Chris Wineinger
> > Interior Systems Inc.
> > --- In vantage@yahoogroups.com, "Stan Chmura" <schmura@> wrote:
> > > Progress.
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > > Len Hartka
> > > Sent: Tuesday, March 19, 2013 10:25 AM
> > > To: vantage@yahoogroups.com
> > > Subject: RE: [Vantage] 701
> > > Good Day:
> > > SQL or Progress?
> > > Len
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> > > Behalf
> > > Of stanchmura
> > > Sent: Tuesday, March 19, 2013 9:51 AM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] 701
> > > Hi:
> > > Over the weekend I upgraded from 9.05.700C to 9.05.701. Unfortunately, I
> > > discovered a real performance problem with Part tracker, and other
> > > functions that touch the part master. e.g. after opening part tracker,
> > > searching for a part, and choosing one, it takes about 30 seconds
> > > minimum to load the data in the tracker form. This is clearly a result
> > > of the 701 patch. These delays were not seen prior to applying 701.
> > > Similar delays are also happening in Job entry when getting details, and
> > > other part functions. Any one see this too? I have been talking with
> > > Epicor. At this time, they think there may be a missing dll at the
> > > client or something, and I am promised a fix ASAP.
> > > Stan
> > > This e-mail and any attachments may contain proprietary and/or confidential
> > > information. If you are not the intended recipient, please notify the sender
> > > immediately by reply e-mail or at 410-472-2900 and then delete the message
> > > without using, disseminating, or copying this message or any portion
> > > thereof. With e-mail communications you are urged to protect against
> > > viruses.
