All;
I have information on this error: Record has been modified by
another user....
Basically (in a nut shell) From Patch to Service Pack to Version,
Epicor changes the data formats of fields within tables. Most of the
issues are around numberic type fields, but the one I was reporting
on was JobOper.CommentText.
If you are Progress, Epicor recommends using a dump-n-load program
that scrubs the data as it loads back in and corrects the field
format variances. If you have any questions on that...call Epicor.
If you are SQL, you must capture the DETAILED error in a screen shot,
send them a copy of your DB...hope they can re-create the error, and
they will send you a new .r program that it to fix the error.
another user....
--- In vantage@yahoogroups.com, "pvolkert365" <pvolkert@...> wrote:
> We are on 403B, Progress. We have had the problem since going from
> 8.00 to 8.03.305. We have seen it in Payroll, Engineering
Workbench,
> PO Entry, and Quote Entry. The Payroll one was particularly bad
> because it happened every time to the same record, and we could not
> change a deduction we had to change. Epicor sent us a fix program,
> and it has been fine. We have done two dump & loads. Engineering
no
> longer gets it. PO Entry only gets it if the buyer approves a PO
and
> then tries to go right back in and make more changes. The worst
one
> we are seeing now is Quote Entry. We only have one Quote Entry
> person and he gets it all the time.
> -Peter
> --- In vantage@yahoogroups.com, "Paul V. Blais" <pblais@> wrote:
> > This used to be an awful issue for us...Progress...now it is a
> nuisance.
> > We see it in PO Entry, Part Entry, and Job Entry, it really is an
> odd
> > issue.
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Todd Hofert
> > Sent: Tuesday, December 11, 2007 8:45 AM
> > Subject: RE: [Vantage] 8.03.403x - Job Entry: Record has been
> modified
> > by another user....
> > Patty,
> > We are on 8.03.403C and we are almost plagued by this issue,
mainly
> in
> > Job Entry but occasionally in other areas. We are Progress and
have
> > listened to the suggestion by support that it is the result of a
> data
> > conversion from previous versions...we didn't convert from
previous
> > version. We did the recommended dump and load twice anyway with no
> > resolution. We have been asked to run black box software to
capture
> the
> > error because no one else has the issue nor can it be duplicated.
We
> > have done this and submitted the results to support with no
> resolution.
> > Right now we are dealing with it with the save early and save
often
> > mentality.
> > Todd Hofert
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%
> 40yahoogroups.com> ] On
> > Behalf
> > Of bpbuechler
> > Sent: Tuesday, December 11, 2007 8:37 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] 8.03.403x - Job Entry: Record has been
modified
> by
> > another user....
> > I would like to know of all customers that are on 8.03.403a, b, c
> or d
> > How many of you are getting this error?
> > Are you on a SQL DB?
> > What was your resolution, if any?
> > Thanks
> > Patty Buechler
> > UV Color, Inc.
> > This e-mail and any attachments may contain confidential and
> privileged
> > information. If you are not the intended recipient, please notify
> the
> > sender immediately by return e-mail, delete this e-mail and
destroy
> any
> > copies. Any dissemination or use of this information by a person
> other
> > than the intended recipient is unauthorized and may be illegal.
