8.03.4XX Customization Question (Time editor Field)
So I binded it to a date field, but when I enter a value and try to tab out of the field I am recieving an error that states: "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Object cannot be cast from DBNull to other types" Do you know what could be causing this?
Â
Dustin Biniek
DustinB@...
Sent: Tuesday, November 18, 2008 11:07:33 AM
Subject: [Vantage] Re: 8.03.4XX Customization Question (Time editor Field)
Bind it to a date/time field like Date01
--- In vantage@yahoogroups .com, melissa hietala <kevmel822@. ..> wrote:
> I am looking at adding a field to a screen to track a time
value.  I originally had added a "textbox" to the screen, but this
doesn't seem like the best way to go because users
could potentially enter anything they want instead of entering a
valid time (Ex: 4:30 pm). So now I've added a "TimeEditor" field to
the screen. This seems like a much better option. However, when I
try to tie this "TimeEditor" field to a user defined field such
as "Character01" I am recieving an error message that says "Input
string was not in a correct format."Â My question is how are people
tying a "TimeEditor" field to a user defined field so that it can be
displayed on a Vantage screen and also be pulled into a Crystal
Report?
> Thank you,
> Â
> Dustin Biniek
> DustinB@...
I am looking at adding a field to a screen to track a time value.  I originally had added a "textbox" to the screen, but this doesn't seem like the best way to go because users could potentially enter anything they want instead of entering a valid time (Ex: 4:30 pm). So now I've added a "TimeEditor" field to the screen. This seems like a much better option. However, when I try to tie this "TimeEditor" field to a user defined field such as "Character01" I am recieving an error message that says "Input string was not in a correct format." My question is how are people tying a "TimeEditor" field to a user defined field so that it can be displayed on a Vantage screen and also be pulled into a Crystal Report?
Thank you,
Â
Dustin Biniek
DustinB@...
Report?
> Thank you,
> Â
> Dustin Biniek
> DustinB@...
