I am not aware of anyway to change customization menu in the process calling method at runtime.
I need to be able to open a custom MES screen that, when you open the End Activity button, it opens a customized one. The trick is, I need this customization to work for a hand full of users. Not company wide.
In the Process Calling Maintenance:
Called Process Reference = Epicor.Mfg.UI.EndActivityEntry
Called From = ?????
Menu ID = UDMES2EA (the customization that I need)
When I leave the "Called From" entry blank, the customization works, but company wide.
When I click on End Activity button from my customized MES screen in developer mode, the "Calling App" = Epicor.Mfg.Menu.Mes. This should be what I need to put in the Called From box, but all MES screens use the same Calling App therefore makes it company wide. Is there any way to specify a different calling app for the customized MES screen?
Mfgsys config on each machine can point to a custom mes menu
On Mar 13, 2015 8:09 PM, "wiztech432@... [vantage]" <vantage@yahoogroups.com> wrote:Â<div> <p><p><span>I need to be able to open a custom MES screen that, when you open the End Activity button, it opens a customized one. The trick is, I need this customization to work for a hand full of users. Not company wide.<br><br></span></p><p><span>In the Process Calling Maintenance:</span></p><p><span><br></span></p><p><span>Called Process Reference = Epicor.Mfg.UI.EndActivityEntry<br>Called From = ?????</span></p><p><span>Menu ID = UDMES2EA (the customization that I need)</span></p><p><span><br></span></p><p><span>When I leave the "Called From" entry blank, the customization works, but company wide.</span></p><p><span>When I click on End Activity button from my customized MES screen in developer mode, the "Calling App" = Epicor.Mfg.Menu.Mes. This should be what I need to put in the Called From box, but all MES screens use the same Calling App therefore makes it company wide. Is there any way to specify a different calling app for the customized MES screen?</span></p> </div> <div style="color:#fff;min-height:0;"></div>
I agree. But I want to use a customization for the End Activity screen on the customized MES screens only for a hand full of people.
Thank you,
Adam Smith | IT Manager
Lapeer Industries
400 McCormick Dr., Lapeer, MI 48446
Phone: (810) 664-1816
Fax: (810) 664-7182
Sent: Friday, March 13, 2015 8:18 PM
To: Vantage
Subject: Re: [Vantage] 8.03 MES Customization
Called From = ?????Menu ID = UDMES2EA (the customization that I need)
This is an e-mail from Lapeer Industries, Inc. It is for the intended recipient only and may contain confidential and privileged information.
No one else may read, print, store, copy, forward or act in reliance on it or its attachments.
If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer.
Your cooperation is appreciated.
