Patrick
On Dec 2, 2013, at 3:01 AM, "ross.hughes3@..." <ross.hughes3@...> wrote:
<div id="ygrps-yiv-803373698ygrp-text">
<p></p><p>Hi Patrick,</p><p> </p><p>I am not sure it is a Crystal viewer issue. I had the same issue getting details from the Journal Tracker. </p><p> </p><p>The only way I can get the thing to return the records was to call the mfgsys64.exe file instead of the mfgsys.exe file. Of course, you have to run it in a 64-bit environment.</p><p> </p><p>This solved the immediate problem but I am sure this will impact external assemblies in customizations if they do not support 64-bit.</p><p> </p><p>Ross<var id="ygrps-yiv-803373698yui-ie-cursor"></var></p><p> </p> <div class="ygrps-yiv-803373698ygroups-quoted"><br><br>---In <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>, <vic.drecchio@...> wrote:<br><br><div id="ygrps-yiv-803373698ygrps-yiv-171714001"><div class="ygrps-yiv-803373698ygrps-yiv-171714001WordSection1"><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;">Ah, well yes, that does seem like a PITA. Have you tried another runtime version? Perhaps give that a shot on your test PC.</span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;">I think most runtime releases are here:</span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"><a rel="nofollow" target="_blank" href="http://wiki.scn.sap.com/wiki/pages/viewpage.action?pageId=56787567">http://wiki.scn.sap.com/wiki/pages/viewpage.action?pageId=56787567</a></span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><div><div style="border-width:1pt medium medium;border-style:solid none none;border-color:rgb(181, 196, 223) currentColor currentColor;"><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><b><span style="font-size:10pt;">From:</span></b><span style="font-size:10pt;"> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a> [<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">mailto:vantage@yahoogroups.com</a>] <b>On Behalf Of </b>Winter, Patrick<br><b>Sent:</b> Tuesday, October 01, 2013 3:14 PM<br><b>To:</b> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a><br><b>Subject:</b> RE: [Vantage] 9.05.702 - BAQ Report to Crystal - 'System.OutOfMemoryException'</span></p></div></div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"> </p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"> </p><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-mlmsg"><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-msg"><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-text"><div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">It’s a Crystal Viewer thing, I have Crystal Runtime 2010 SP3, Crystal Developer 2008 SP4. </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Can’t print and view I get the “System.OutOfMemeoryException†do to parsing I’m told by support.</span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">If I print from Crystal Developer it works Great. </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> </span></p><div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><b><span style="color:rgb(31, 73, 125);font-size:11pt;">Patrick Winter</span></b></p></div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> </span></p><div><div style="border-width:1pt medium medium;border-style:solid none none;border-color:rgb(181, 196, 223) currentColor currentColor;"><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><b><span style="font-size:10pt;">From:</span></b><span style="font-size:10pt;"> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a> [<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">mailto:vantage@yahoogroups.com</a>] <b>On Behalf Of </b>Vic Drecchio<br><b>Sent:</b> Tuesday, October 01, 2013 13:55<br><b>To:</b> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a><br><b>Subject:</b> RE: [Vantage] 9.05.702 - BAQ Report to Crystal - 'System.OutOfMemoryException'</span></p></div></div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"> </p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"> </p><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-mlmsg"><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-msg"><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-text"><div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;">Is this a report that you could dump the results to XML via the BAQ Export Process? I have many reports in excess of that record-count that I do the same thing that you’re doing. I may dump the data nightly as these historical trend/analysis reports are fine with a static dataset from last night. </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;">Or, if you have SQL, go SQL ODBC for this report.</span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;">Is this bug a E9 thing? I’m also very certain I have BAQ--> Crystal reports exceeding a simple 41,000 records…… I’m on 8.03.4xx.</span></p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:blue;"> </span></p><div><div style="border-width:1pt medium medium;border-style:solid none none;border-color:rgb(181, 196, 223) currentColor currentColor;"><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><b><span style="font-size:10pt;">From:</span></b><span style="font-size:10pt;"> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a> [<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">mailto:vantage@yahoogroups.com</a>] <b>On Behalf Of </b>Winter, Patrick<br><b>Sent:</b> Tuesday, October 01, 2013 2:15 PM<br><b>To:</b> <a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a><br><b>Subject:</b> [Vantage] 9.05.702 - BAQ Report to Crystal - 'System.OutOfMemoryException'</span></p></div></div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"> </p><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"> </p><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-mlmsg"><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-msg"><div id="ygrps-yiv-803373698ygrps-yiv-171714001ygrp-text"><p>All,</p><p>Simple request a 3 column sales analysis report, three years of invoices, 41000 records.</p><p>(One of the oldest reports known to Data Processing)</p><p><b>Since Epicor 9 has a (Crystal Viewer / .net / XML) allocation memory block limitation</b></p><p><b>in parsing data a BAQ to XML to Crystal doesn’t work.</b></p><p>Any workaround, fixes, ideas, etc…</p><p>Tech Support says it’s a known limitation, you will have to process less data as in not run it </p><p>for 3 years. (They are funny guys….)</p><p>I have stripped the BAQ as much as possible, no character description fields X(1000), etc…</p><p>What is the best alternative to creating reports where you actually have </p><p>to process 40,000 or more records of records with multiple subtotals etc…?</p><p><b>Patrick Winter</b></p></div></div></div></div></div></div></div></div></div><div><p class="ygrps-yiv-803373698ygrps-yiv-171714001MsoNormal"><span style="color:white;"></span></p></div></div></div></div></div></div><p></p>
</div>
