9.05.702A Crystal Reports Version
For E9 yes. Though 2008 is the minimum supported you might want to ask the question if any later versions/service packs are compatible with E9. 2008 is a fairly old product by this point. Might be worth an ask I don’t know off the top of my head what the max version of Crystal supported is for E9.
Josh
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Kimberley White
Sent: Tuesday, September 10, 2013 10:54 AM
Subject: Re: [Vantage] 9.05.702A Crystal Reports Version
So if I order Crystal Reports 2008 that will be the correct version?
I can install Developer and at service packs and I will be ok??
Thanks Kim
Sent: Tuesday, September 10, 2013 11:20 AM
Subject: RE: [Vantage] 9.05.702A Crystal Reports Version
The version number they reference is v12 that is Crystal 2008.  On Epicor’s FTP site are all the service packs you will need. Do not install the base 2008 Developer and plow forward… you’re gonna have a bad time.
Josh
Sent: Tuesday, September 10, 2013 9:25 AM
THank you.
What version of Crystal Reports can I use with Epicor 9.05.702A?  Support told me 2008.  I have 8.5 which works and version XI that won't open any files.
Suggestions on what version I should be using.
Thanks Kim
2008 like support said... Version XI is for 8.03> < 9.0
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@…
http://www.josecgomez.com
     Â
On Tue, Sep 10, 2013 at 9:18 AM, <faepigrl@...> wrote:
Â
<div>
  <p></p><p></p><p>What version of Crystal Reports can I use with Epicor 9.05.702A?  Support told me 2008.  I have 8.5 which works and version XI that won&#39;t open any files.</p><p> </p><p>Suggestions on what version I should be using.</p>
Â
Thanks Kim
</div>
<div style="color:#fff;min-height:0;"></div>
THank you.
To: Vantage <vantage@yahoogroups.com>
Sent: Tuesday, September 10, 2013 9:29 AM
<div id="ygrps-yiv-2089100594yiv8815021206ygrp-text">
  <div dir="ltr"><div class="ygrps-yiv-2089100594yiv8815021206gmail_default" style="font-family:verdana, sans-serif;font-size:small;">2008 like support said... Version XI is for 8.03&gt; &lt; 9.0</div></div><div class="ygrps-yiv-2089100594yiv8815021206gmail_extra"><div><div><font face="verdana, sans-serif"><br>
Jose C Gomez
Software Engineer
<div>
  <div>What version of Crystal Reports can I use with Epicor 9.05.702A?&nbsp; Support told me 2008.&nbsp; I have 8.5 which works and version XI that won&#39;t open any files.</div><div>&nbsp;</div><div>Suggestions on what version I should be using.</div>
Thanks Kim
</div>
<div style="color:rgb(255, 255, 255);"></div>
</div>
Josh
THank you.
Thanks Kim
<div id="ygrps-yiv-1555029464yiv6291746439ygrp-text">
  <div class="ygrps-yiv-1555029464yiv6291746439WordSection1"><div class="ygrps-yiv-1555029464yiv6291746439MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">The version number they reference is v12 that is Crystal 2008.&nbsp; On Epicor’s FTP site are all the service packs you will need. Do not install the base 2008 Developer and plow forward… you’re gonna have a bad time.</span></div><div class="ygrps-yiv-1555029464yiv6291746439MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div class="ygrps-yiv-1555029464yiv6291746439MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;">Josh</span></div><div class="ygrps-yiv-1555029464yiv6291746439MsoNormal"><span style="color:rgb(31, 73, 125);font-size:11pt;"> &nbsp;</span></div><div><div style="border-top-color:rgb(225, 225, 225);border-top-width:1pt;border-top-style:solid;"><div class="ygrps-yiv-1555029464yiv6291746439MsoNormal"><b><span style="font-size:11pt;">From:</span></b><span style="font-size:11pt;"> vantage@yahoogroups.com
THank you.
From: Jose Gomez <<a rel=“nofollow” target=“_blank” href=“mailto:jose@…”
jose@…>
2008 like support said… Version XI is for 8.03> < 9.0
Jose C
Gomez
Software Engineer
</div>
