Based upon what epicor support has said. Although you can convert your existing
crystal XI report to crystal 2008 their is an issue with dynamic parameter which
causes the headache. Based upon what I have seen the dynamic parameters does
not present the data for users to select from.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tue, August 24, 2010 8:46:05 AM
Subject: RE: [Vantage] 9.05 install
Â
Paul,
Why would you have to rewrite reports (other than for schema changes)?
Dolores
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Paul
L Bennett
Sent: Monday, August 23, 2010 3:38 PM
Subject: Re: [Vantage] 9.05 install
Greg,
We moved from 8.03 to 9.05 sucessfully using the document but they were
challenges. I suggest you do the installation on a test machine repetatively
until you are comfortable before you move to your production system. Make sure
you have atleast 10GB free on your C drive other wise horrors. I had an issue
with INS-STK transactions being duplicated in my data base but this seems to
only occur in some clients i.e. this issue is not wide spread...) Sigh I am
still waiting to have this resolved....Hmmmm. Anyhow you need to determine
whether you are going to the 64 bit progress or 32 unless you are SQL. A word
for the wise reports will have to be re-written so get going early....If I have
any further thought I will surely let you know
Paul
<greg.middleton@...<mailto:greg.middleton%40machspec.com>>
Sent: Mon, August 23, 2010 3:09:59 PM
Subject: [Vantage] 9.05 install
We are currently on Vantage 6.1 and upgrading to 9.05. We would like to install
9.05 ourselves on a new server using the Epicor 9.05 Installation Guide, and let
Epicor do the data conversions for us. Has anybody successfully completed this
installation just using the Installation Guide and not using Epicor services to
install? Is the Install Guide complete and accurate enough to get us there?
Thanks.
Â
Paul,
Dolores
L Bennett
Greg,
Paul
Thanks.
