You probably already have considered the following, but just in case ...
In W98, you can use a windows accessible version of IPConfig (Start -
Run - browse to C:\windows - look for the IPConfig.exe program). When
the disconnect has occurred run IPConfig and see if a "renew" brings it
back. If so, check the power settings (control panel) set to always
on. Also, check the BIOS settings (on the bootup - go into "setup") to
disable any hibernation, shutdown or sleep mode.
If that doesn't do it, check that the router settings aren't the cause.
Check scheduled tasks. Make sure something isn't scheduled to run that
interferes with the network port.
Although unlikely, check to make sure there is no VPN or VNC activity
with this machine. (When they run, the network connection is usually
disabled.)
You could have some kind of malware trying to get out that interferes
with the network card when it initiates. If you don't have one running,
put a software firewall on (such as ZoneAlarm - http://www.zonelabs.com
- basic version free) to troubleshoot that issue.
If it still isn't solved, you may have to start considering some
hardware issues (ie., power supply problems, fan cooling - overheating,
etc.). For example, PC overheats, begins a shutdown, etc,. etc; or, how
much drive space is available; or, memory & drive health.
Hope this helps.
Dan Baier
Richard Bailey wrote:
Daniel J. Baier, CPA, P.C.
350 Calkins Road
Rochester, NY 14623
Phone: (585) 334-1640
Fax: (585) 334-1648
Efax: (514) 379-5728
Email: DanBaier@...
DanBaier@...
This Email is intended only for use by the person to which it is
addressed. It may contain confidential and/or privileged material.
If the Email is received in error, do not use, copy or disseminate
the information. Please delete the files and contact sender.
E-mail transmission cannot be guaranteed to be secure or error-free
as information could be intercepted, corrupted, lost, destroyed,
misdirected, or contain a wide range of harmful elements commonly
referred to as viruses. The sender does not accept any liability
for any such faults in connection with this message. If verifi-
cation is required as to authenticity of this message, please
contact the sender. [A20M-0601]
disabled.)
Hope this helps.
Dan Baier
> Has anybody come across a situation where a PC automatically disconnects--
> itself from the network after a certain period of inactivity?
> We've got a Windows 98 PC used in the shop for viewing drawings etc (not
> Vantage). The users reckon that if there is no activity for c.2 hours then
> the PC disconnects from the network and then has to be reconnected.
> Any ideas anyone
> Regards,
> Richard
> Richard Bailey
> Dudley Industries
> Mailto: rbailey@...
> Tel: +44(0)1253 738311
> Mob: +44(0)7836 550360
> Fax: +44(0)870 7628173
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> SPONSORED LINKS
> Manufacturing software
> <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
> Membership database software
> <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
> Database mortgage software
> <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
> Pda database software
> <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
> Database management software
> <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
> Database marketing software
> <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
> YAHOO! GROUPS LINKS
> * Visit your group "vantage
> <http://groups.yahoo.com/group/vantage>" on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
>No virus found in this incoming message.
>Checked by AVG Free Edition.
>Version: 7.1.375 / Virus Database: 267.15.2/253 - Release Date: 2/7/2006
350 Calkins Road
Rochester, NY 14623
Fax: (585) 334-1648
Email: DanBaier@...
DanBaier@...
