Dear experts,
Getting below error in AR Invoice entry.Please suggest how to resolve this.
A valid ExpirationYear is required.
Error Detail
Description: A valid ExpirationYear is required.
Program: Erp.Services.BO.ARInvoice.dll
Method: validateCreditCard
Line Number: 33797
Column Number: 17
Table: ttInvcHead
Field: ExpirationYear
Server Trace Stack: at Erp.Services.BO.ARInvoiceSvc.validateCreditCard() in C:_Releases\ERP\UD10.2.200.16\Source\Server\Services\BO\ARInvoice\ARInvoice.cs:line 33797
at Erp.Services.BO.ARInvoiceSvc.InvcHeadBeforeUpdate() in C:_Releases\ERP\UD10.2.200.16\Source\Server\Services\BO\ARInvoice\ARInvoice.cs:line 16787
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 146
at Ice.TablesetBound3.UpdateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow updatedRow, IceRow originalRow, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1289 at Ice.TablesetBound
3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 997
at Ice.TablesetBound3.InnerUpdate[TUpdater](IceDataContext dataContext, TFullTableset tableset) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 892 at Erp.Services.BO.ARInvoiceSvc.UpdateMaster(ARInvoiceTableset& ds, String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan) in C:\_Releases\ERP\UD10.2.200.16\Source\Server\Services\BO\ARInvoice\ARInvoice.cs:line 32670 at Epicor.Customization.Bpm.BOC2625DF743A843D6823A62DD92A3B4DE.UpdateMasterImpl.ExecuteBase(UpdateMasterParameters parameters) at Epicor.Customization.Bpm.MethodCustomizationBase2
3.RunDirectives(TParam parameters) in C:_Releases\ICE\ICE3.2.200.16\Source\Server\Internal\Lib\Epicor.Customization.BPM\MethodCustomizationBase2.cs:line 197
at Epicor.Customization.Bpm.CustomizationBase23.Execute(TParam parameters) in C:\_Releases\ICE\ICE3.2.200.16\Source\Server\Internal\Lib\Epicor.Customization.BPM\CustomizationBase2.cs:line 73 at Epicor.Customization.Bpm.BOC2625DF743A843D6823A62DD92A3B4DE.ARInvoiceSvcCustomization.UpdateMaster(ARInvoiceTableset& ds, String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan) at Erp.Services.BO.ARInvoiceSvcFacade.UpdateMaster(ARInvoiceTableset& ds, String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan) in C:\_Releases\ERP\UD10.2.200.16\Source\Server\Services\BO\ARInvoice\ARInvoiceSvcFacade.cs:line 7309 at SyncInvokeUpdateMaster(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func
2 func) in C:_Releases\ICE\ICE3.2.200.16\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:\_Releases\ICE\ICE3.2.200.16\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\ICE3.2.200.16\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener
1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.ARInvoiceImpl.UpdateMaster(ARInvoiceDataSet ds, String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan)
at Erp.Adapters.ARInvoiceAdapter.UpdateMaster(String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan)
at Erp.Adapters.ARInvoiceAdapter.UpdateMasterUsingPasteInsert(String cGroupID, String cTableName, Boolean runCheckAmortSched, Boolean runChkLtrOfCredit, Boolean& genAmortSched, Boolean lRASchedExists, Int32 ipInvoiceNum, Int32 ipInvoiceLine, String cARLOCID, Boolean suppressUserPrompts, Decimal dTotalCharges, Boolean lGetDefaultAccount, Decimal& grpTotalInvAmt, String& opGenMessage, String& opLtrCrdMsg, Boolean& lUpdateRan, String pasteInsertColumnsToValidate)
at Erp.UI.App.ARInvoiceEntry.Transaction.Update(Boolean refreshGroup)
