That’s good to know. I always thought it was a static class.
On Behalf Of Jose Gomez
Sent: Friday, November 15, 2013 9:47 AM
To: Vantage
Subject: Re: [Vantage] RE: RE: Access CallContextBPM Data in C# code
CallContextBpmData is supposed to be ubiquitous (for a given screen) so that any call you make within the same screen should carry it.
On Fri, Nov 15, 2013 at 9:30 AM, <livingstonmh@...> wrote:
Ok after so research I think I figured out why I am not getting the data.
From what I understand the CallContextBPMData is for specific. Is it possible that since I am using a data directive that I am writing to the wrong callcontext? I am calling the TransferWorkBenchDataSet.GetByID method, so I am gussing that might be where it is pulling the callcontext data from. Does anyone know if it would be possible to change the Context data that I am writing to?
---In vantage@yahoogroups.com, <livingstonmh@...> wrote:If you see my response I posted the code. It is on a customized replenishment workbench form.
I know that the MessageBox.Show(string.Concat("Orders Created\n",Orders)); only displays at the end, so I put the code at the end of the private void CreateOrder(Infragistics.Win.UltraWinGrid.UltraGridRow row).
---In vantage@yahoogroups.com, <david03350@...> wrote:
Since your c# code is in a customization, maybe you're accesing that field before your bpm triggers? What form/method are you putting your code on?
I need to access data that was written to the CallContextBPM.Character01 field in C#
I am using the below now:
EpiDataView edvt = ((EpiDataView)(this.oTrans.EpiDataViews["CallContextBpmData"]));
string edvts = edvt.dataView[edvt.Row]["Character01"].ToString();
MessageBox.Show(edvts);
However it is always showing empty.
I have attached a datadirective bpm to TFOrdDtl and when the TFOrdNum field is set I then set this BPM data field to the TFOrdNum. After this runs I need to access it in the C# program.
This is basically a customization to the Transfer Order Workbench where when transfer orders are created I want to record the first order's number, and then set all orders created after that to the same number. Since this TFOrdNum is not available when this procress is run I had to use the TFOrdDtl datadirective to set a bpm field for the first one, and then I can use another BPM to set everything after that to the same thing.
Anyone have any ideas on how to do this?
