Add column to an EpiDataView
Not directly. You can create your own VB.NET defined data array and populate it from one or more EpiDataviews as well as non vantage data via an odbc/SQL function... Then you can display that.
The behavior can be a little flaky though so I wouldn't do it for a high activity use app.
Rob
--- On Mon, 2/9/09, sgotschall <sgotschall@...> wrote:
Subject: [Vantage] Add column to an EpiDataView
Date: Monday, February 9, 2009, 3:00 PM
Vantage 8.03.407 Progress
Is it possible to add columns to a built in EpiDataView? Specifically,
I would like to add some fields from the Customer Table to the
InvHeaderList EpiDataView on the Customer Invoice entry form. I can
pull the data in through a Foreign Key View but now I want it to show
up in the Epidataview with the rest of the invoice header informaion.
I figured I could create a new view from scratch, but this seems like a
lot of work just to add a couple of columns.
