Adding conditional text field - Crystal 8.0
Dick,
Some dotmatrix printers have trouble with text fields, ironically. Try using a formula instead of a text box. Then in the formula enter your text in Quotes. Use the same conditional suppress for the formula as you did for the text box and see if that works for you.
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'Vantage (vantage@yahoogroups.com)'
Sent: Wednesday, November 13, 2002 1:39 PM
Subject: [Vantage] Adding conditional text field - Crystal 8.0
I am attempting to add a conditional text field to our AP checks where if
the amount is greater than $10,000, a second signature field is included.
When designing the check, I created and added the text box. I then added a
condition to supress the field if the check amount is less than $10,000.
Crystal accepted the supress formula and I can print the check without any
problem from Crystal.
However, when I print the check in Vantage, I get a 515 error. (bad
formula).
I would certainly appreciate any help/suggestions regarding this matter.
regards,
formula).
regards,
