Hi
First you do need to setup the relationship between the custcunt to shipheader within epicor. This will prevent from exporting all contacts
Then in crystal you have to setup the table relationship because crystal is not good at linking them.
Ephraim Feldman
Programmer / Analyst
Axis Lighting
Sender: vantage@yahoogroups.com
Date: Tue, 01 Feb 2011 15:44:49
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] Adding Customer Contact e-mail to Packing slip.
Hi all,
i am attempting to add the custcnt table to our packing slip.
I have duplicated the syystem packing slip and created a new one.
I am currently on Report data definition. I add the table custcnt and when i go to preview in Crystal reports everything is blank. Im 99% sure that i am missing some sort of link in the report data definition or another table needs to be used as well. attached is a screenshot of the packing slip.
on progress 803.408b.
i have done the following:
1)create duplicate report of the system packing slip
2)add a new report table to the duplicated report
3)then use the new report definition for our daily packing slip.
4)go to crystal reports and reload the packing slip with the added new table?
Ephraim Feldman
Axis Lighting
Hi all,
