Adjusting material on a job
Dina,
It almost seems as though it does everything BUT reduce the on hand qty. Is
this by design or a bug. I think it should. It even shows up in the
transaction history file as a reduction ADJ-MTL.
Epicor care to explain????
Thanks for the replies....
Darren Mann
Sent: Thursday, February 27, 2003 7:46 AM
Subject: RE: [Vantage] Adjusting material on a job
I'm still on 4.0 but job material adjustment does not reduce inventory
but it will remove the "allocation" of the part under part tracker! If
you job material adjust a part it will show on the job that the material
has been issued but it will not reduce inventory!
Best Regards,
Dina Hieber
Vamco International, Inc.
(412) 963-7100 Phone
(412) 963-9511 Fax
Sent: Thursday, February 27, 2003 8:31 AM
To: 'vantage@yahoogroups.com'
Hold the phone! Using Subcontract job adjustments as the example.......
there is a G/L transaction involved with such an dollar adjustment.
Debit to Subcontract WIP account and credit to the Adjustment Expense
account. So I am of the impression that it does affect inventory. You
can adjust quantities also. Haven't tried a quantity adjustment without
a $ adjustment to see if that doesn't affect inventory.
Are you indicating that this changes in later versions? Can't imagine
that happening!!!
Deb Wilmoth
Controller
Reeder & Kline Machine Company, Inc.
Vantage 5.0
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.458 / Virus Database: 257 - Release Date: 2/24/2003
Version 5.1 -
Should a job material adjustment reduce the onhand qty of the part in
inventory? If we do a labor adjustment it will when materials are linked to
that operation.
Darren Mann
Miller Products Co.
I was always under the impression that job adjustments only affected the job
(not inventory or labor entry). I don't know if it is a bug or a
undocumented feature.
Alex Neutgens
Controller
Synovis Interventional Solutions
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Sent: Wednesday, February 26, 2003 2:01 PM
To: Vantage User Group (E-mail)
Subject: [Vantage] Adjusting material on a job
Version 5.1 -
that operation.
Darren Mann
Miller Products Co.
there is a G/L transaction involved with such an dollar adjustment. Debit
to Subcontract WIP account and credit to the Adjustment Expense account. So
I am of the impression that it does affect inventory. You can adjust
quantities also. Haven't tried a quantity adjustment without a $ adjustment
Are you indicating that this changes in later versions? Can't imagine that
happening!!!
Deb Wilmoth
Controller
Vantage 5.0
Sent: Wednesday, February 26, 2003 11:30 PM
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Version 5.1 -
that operation.
Darren Mann
Miller Products Co.
The material is affected if you are using backflush features. If you adjust
the quantity completed on a part that the material was backflushed or is set
up to be backflushed, the material will be issued accordingly.
If you make a positive adj to the qty the material will be issued to the
job. If you make a negative adj to the qty then the material will be
unissued and returned to inventory.
Considering the concept of backflushing, this makes sense. If this is
undesirable then one must consider whether backflushing is appropriate for
you. Backflushing is as dangerous as it is convenient.
I try to review all job travelers after the parts are completed and make
corrects at that point, and because the part was just made I update the
labor record and do not do an adjustment.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone: 401-596-0162 x110
Fax: 401-596-1050
www.maxsonautomatic.com
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Version 5.1 -
that operation.
Darren Mann
Miller Products Co.
Best Regards,
Dina Hieber
(412) 963-9511 Fax
that happening!!!
Deb Wilmoth
Controller
Vantage 5.0
job (not inventory or labor entry). I don't know if it is a bug or a
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Version 5.1 -
linked to that operation.
Darren Mann
Miller Products Co.
You are correct. Material adjustment do not impact inventory qty's. A
material adjustment increases WIP material and a variance account (inventory
adjustments or something.)
May point was that inventory qtys are only affected if you update the qty
completed and you use backflushing.
Controller
Fax: 401-596-1050
Sent: Thursday, February 27, 2003 8:46 AM
Best Regards,
Dina Hieber
(412) 963-9511 Fax
that happening!!!
Deb Wilmoth
Controller
Vantage 5.0
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Version 5.1 -
Darren Mann
Miller Products Co.
We have WIP, finished goods and raw material inventories. WIP is inventory.
Then people can have different G/L numbers set for finished goods inventory
or raw material inventories. We sometimes need to be more specific when
addressing a question. The example I gave does affect G/L numbers and the
WIP report. Dollar Adjustments do carry G/L consequences is the point I am
making.
Quantity adjustments to part numbers can also be made.
The answer to Darren's question may more correctly be defined in saying that
if you enter a job adjustment with a quantity in addition to dollars, then
quantities can be affected. However, if you enter an adjustment for dollars
only, it does not affect the job quantity.
Deb Wilmoth
Controller
Vantage 5.0
Sent: Thursday, February 27, 2003 8:57 AM
Controller
Fax: 401-596-1050
Best Regards,
Dina Hieber
(412) 963-9511 Fax
that happening!!!
Deb Wilmoth
Controller
Vantage 5.0
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Version 5.1 -
Darren Mann
Miller Products Co.
It does do a GL transaction, but does not affect the inventory GL or
inventory on hand. In any event, job adjustments should be used sparingly.
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Sent: Thursday, February 27, 2003 7:31 AM
happening!!!
Deb Wilmoth
Controller
Vantage 5.0
Alex Neutgens
Controller
Phone: 651-792-2869
Fax: 651-792-2801
aneutgens@...
Version 5.1 -
that operation.
Darren Mann
Miller Products Co.
