After 2025.2 Upgrade, my Packslip ssrs report I built quit working
Hello,
Has anyone seen an error like this when trying to run a custom SSRS report that worked before the upgrade?
The Standard SSRS report runs so I assume they changed something. Just don’t know what or how to track down without rebuilding report from scratch…
I am Gov Cloud so I don’t have access to servers to see any logs.
System.ArgumentNullException: Value cannot be null. (Parameter 'key')
   at System.Collections.Generic.Dictionary`2.FindValue(TKey key)
   at System.Collections.Generic.Dictionary`2.TryGetValue(TKey key, TValue& value)
   at Ice.Core.RptTaskBase`1.XMLDumpTable(IRow row, String rptTableId) in C:\_releases\ICE\ICE5.1.100.7\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 265
   at Erp.Internal.SR.PackingSlipPrint.doShipHead() in C:\_releases\ERP\ERP12.1.100.7\Source\Server\Internal\SR\PackingSlipPrint\PackingSlipPrint.cs:line 2305
   at Erp.Internal.SR.PackingSlipPrint.RunProcess(Int64 Instance_TaskNum, String OutputFile) in C:\_releases\ERP\ERP12.1.100.7\Source\Server\Internal\SR\PackingSlipPrint\PackingSlipPrint.cs:line 1088
   at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_releases\ICE\ICE5.1.100.7\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 71
   at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_releases\ICE\ICE5.1.100.7\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 62
   at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 57
   at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_releases\ICE\ICE5.1.100.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 349```
yup theres a thread a few down
You have to manually fix your RDD. Jose posted the solution here.
This was exactly it!
Thanks for pointing me in the right direction.
You bet! Glad it worked for you!
