We have the cheapo Chip PC TC in the shop. They've been out there for 5 years and are still alive and kicking...even in this Texas heat.
Hopefully I haven't jinxed myself.
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> Thanks everyone J
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of sbraudrick@...
> Sent: Monday, June 06, 2011 8:36 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: any recomendations for thin client hardware to
> run MES on the shop floor?
> I'll 3rd the HP recommendation. I use mine to connect to full VMs on a
> XenServer host, so far with no real problems. The only issue we had was
> easily resolved by my non-technical assistant calling HP support which
> was very helpful.
> I will say that USB pass-through to the VMs is tricky if not impossible
> for some devices. (I can get external HDDs and thumb drives to work but
> no luck so far with printers.) However I'll also admit I haven't had a
> lot of time to spend on it.
> In my opinion, a pretty impressive box for a $200 from NewEgg. (
> http://www.newegg.com/Product/Product.aspx?Item=N82E16859105659&cm_re=HP
> _thin_client-_-59-105-659-_-Product)
> HP also makes a bracket for mounting the thing to the back of a monitor
> which is nice, even at the $20 price tag.
> I don't work for NewEgg or HP either... :)
> Sean B
> Director of IT
> HMU, LLC
> The firmware is straight-forward and easy to set up.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Rob
> Bucek" <rbucek@> wrote:
> > I wanted to put out a single setup to compare performance to our POS
> > units. Its seems to be conceptually speaking a lot cheaper to add and
> > replace and maintain than the full blown pioneers that we have out
> there
> > currently (assuming we have a server dedicated to take on the load,
> > which we do). Running 8.03.409a, any specs I should look for? Thanks!
> > Rob Bucek
> > FAX: (715)284-4084
