Continuing the discussion had in Application Studio - Function Output to Grid - Help Needed.
I am now attempting to write a slightly more complex function to a grid.
using (DataSet outDS = new DataSet("outDS"))
var oDT = new DataTable("outResult"); // Create the DataTable with the name "outResult"
var dfq = new Dictionary<Tuple<string, string>, DataRow>(); // Use string-based tuples for job number and due date
oDT.Columns.Add("OpSeq", typeof(string)); // First column is OpSeq (row labels)
// Sample data (this should be replaced with your actual table from the previous step)
var data = new[] {
new { JobNumber = "109673", DueDate = new DateTime(2025, 2, 8), OpSeq = "10" },
new { JobNumber = "109673", DueDate = new DateTime(2025, 2, 8), OpSeq = "20" },
new { JobNumber = "109673", DueDate = new DateTime(2025, 2, 8), OpSeq = "30" },
new { JobNumber = "109673", DueDate = new DateTime(2025, 2, 8), OpSeq = "40" },
new { JobNumber = "184438", DueDate = new DateTime(2025, 3, 9), OpSeq = "10" },
new { JobNumber = "184438", DueDate = new DateTime(2025, 3, 9), OpSeq = "20" },
new { JobNumber = "184438", DueDate = new DateTime(2025, 3, 9), OpSeq = "30" },
new { JobNumber = "184438", DueDate = new DateTime(2025, 3, 9), OpSeq = "40" },
new { JobNumber = "960313", DueDate = new DateTime(2025, 2, 25), OpSeq = "10" },
new { JobNumber = "960313", DueDate = new DateTime(2025, 2, 25), OpSeq = "20" },
new { JobNumber = "960313", DueDate = new DateTime(2025, 2, 25), OpSeq = "30" },
new { JobNumber = "960313", DueDate = new DateTime(2025, 2, 25), OpSeq = "40" },
new { JobNumber = "996094", DueDate = new DateTime(2025, 3, 6), OpSeq = "10" },
new { JobNumber = "996094", DueDate = new DateTime(2025, 3, 6), OpSeq = "20" },
new { JobNumber = "996094", DueDate = new DateTime(2025, 3, 6), OpSeq = "30" },
new { JobNumber = "996094", DueDate = new DateTime(2025, 3, 6), OpSeq = "40" }
// Add columns for JobNumbers
var jobNumbers = data.Select(d => d.JobNumber).Distinct().ToList();
foreach (var jobNumber in jobNumbers)
oDT.Columns.Add(jobNumber, typeof(string)); // Ensure all columns are of type string
// Populate the DataTable with data
foreach (var entry in data)
var jobNumber = entry.JobNumber;
var dueDate = entry.DueDate.ToString("yyyy-MM-dd"); // Convert DateTime to string (YYYY-MM-DD format)
var opSeq = entry.OpSeq; // OpSeq is already a string
// Check if we have already encountered this OpSeq
var existingRow = oDT.AsEnumerable().FirstOrDefault(r => r.Field<string>("OpSeq") == opSeq);
if (existingRow == null)
// Create a new row for this OpSeq if it doesn't already exist
var newRow = oDT.NewRow();
newRow["OpSeq"] = opSeq; // Set the OpSeq (row label) as string
oDT.Rows.Add(newRow);
existingRow = newRow;
// Find the column for the JobNumber and assign the DueDate value as a string
existingRow[jobNumber] = dueDate;
// Create a simplified output structure
var simplifiedOutput = new List<object>();
foreach (DataRow row in oDT.Rows)
var rowData = new Dictionary<string, string>();
foreach (DataColumn column in oDT.Columns)
rowData[column.ColumnName] = row[column].ToString(); // Ensure everything is converted to string
simplifiedOutput.Add(rowData); // Add the row to the simplified list
// Add the simplified output to the DataSet
outDS.Tables.Add(oDT); // Add the DataTable to the DataSet
// Optionally assign the outDS to a field, if necessary
this.outDS = outDS; // Assuming you need this reference elsewhere in your class
I have the function outputting as it should:
I can see the data attempt to parse when I do my button click event:
The issue I’m running into is that even though the button click successfully shows me the data I am after, it gives me the following error:
And the grid I am using attempts to load columns that were previously in the dataview but have been removed:
What would cause these ghost columns to appear despite not being any of the columns listed within the data?
What is with the random error about everything must be a string when I have everything already converted to a string before it goes into the dataset?
