Application Studio - Kinetic Selectable List
I’m following along with the instructions listed in this post:
I have the list showing as it should, but there is no data populated:
Here are the settings for the list:
Here are the settings for the dataviews:
Here are the settings for the events:
I see data in the returnObj:
I see data in the dataviews:
Where have I gone wrong?
On your dataviews, try changing the Dataset ID and Data Table to match your dataview name. That’s the initial difference I see between your setup and one I created a couple months ago (following Hannah’s instructions).
@cory.davis,
I made those changes and the list is still coming up blank. Any other suggestions?
Also, thanks for the quick response!
Apologies if this is a stupid question but… your set-up is referring to ShortChar02.
Your screen shots are showing data in your dataviews and you’re blocking out Character01 & 02 (for security reasons, no harm there)… but…
Are you using ShortChar02 where you meant to use Character02? If not, can you verify there are values in ShortChar02?
@dcamlin,
That was it!
Thank you!
