AR Clearing acct. not being used - shipments show as MFG-VAR tra
You have to run the INV-WIP Reconciliation by Transaction Type INVOICE to see your invoices. It is second from the end in the drop down list. Are you doing that?
Stephen Schaefer
Abrams Airborne013110
--- In vantage@yahoogroups.com, "Virginia" <vjoseph@...> wrote:
> 8.03.408 we went live on the beginning of this year. We experienced this same issue during testing on 8.03.407 during 2009. Epicor's solution was "Upgrade to the current version" so we upgraded to 408 and this problem was resolved, which I find strange since we made no changes to our company set-up or the process we follow when completing / shipping jobs. We finished testing without further issues. Now that we are live on 408, we are experiencing this same issue.
> I know there have been a lot of discussion on here about MFG-VAR transactions in relation to costing based on Parts with Avg and Std costing, but since we set-up every order/job as make to order, I don't believe I should be seeing any MFG-VAR transactions.
> Here is what I would expect to see: Upon completion of a job and shipment of an order I understand that in the Inventory/WIP Reconciliation report, I should see a MFG-CUS transaction and that transaction should Debit the AR clearing account and Credit the WIP accounts (according to the appropriate product group). Then when the shipments is invoiced the Inventory/WIP Reconciliation Report should show an Invoice transaction that should Debit the COS accounts (according to the appropriate product group) and Credit the AR clearing account.
> Here is what I am actually seeing: When we complete a job and ship the order the Inventory/WIP Reconciliation report shows a MFG-VAR transaction which Debits the COS accounts (according to the appropriate product group) and Credits the WIP account. The invoicing transaction does not result in any transactions showing in the Inventory/WIP Reconciliation report.
> The twist is that I have (4) shipments that I have processed and invoiced in January that have transacted correctly, as described above. All my other shipments are bypassing the AR clearing account, showing as MFG-VAR transactions and moving WIP to COS when the shipment transaction occurs. I have spent several days looking at the Orders/Jobs that transacted correctly compared to the Orders/Jobs that have not and I cannot identify any differences.
> Here is our process:
> We have jobs set-up with BOM's & standards, but nothing is manufactured to inventory and we carry no material in inventory. All material is purchased directly for each job and every order / job we process is make to order, and therefore all our costing comes straight from the job costs.
> 1. When the job is complete, we go to Job Management / Job Closing and check to make sure that the Production Qty. = Complete Qty. and confirm that the final operation is showing as complete. Then we mark the job complete and use the current date. If the complete qty is not correct and/or if the final operation is not showing as complete, that is corrected before we mark the job complete.
> 2. The job is unreleased.
> 3. We create the customer shipment, close the packing slip, print it and confirm that it is marked shipped.
> At this point I go to the Inventory/WIP reconciliation report and expect to see my MFG-CUS transaction with a DR to AR clearing and a CR to WIP. Instead I see a MFG-VAR transaction that has a DR to COS and a CR to WIP.
> I have gone through the whole process with Epicor of confirming that my AR clearing account is populated in Company Maintenanc, confirming that the packing slips are marked shipped, etc.
> Any ideas?
> Virginia Joseph
> IT Director
> Deep Hole Specialists, LLC
> vjoseph@...
> 440-543-8157
Any ideas?
Virginia Joseph
IT Director
vjoseph@...
440-543-8157
What is the reasoning for unreleasing the job?
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Virginia
Sent: Wednesday, January 13, 2010 9:17 AM
Subject: [Vantage] AR Clearing acct. not being used - shipments show as
account.
costs.
WIP.
Any ideas?
Virginia Joseph
IT Director
vjoseph@... <mailto:vjoseph%40deephole.com>
440-543-8157
We mark the job unreleased because marking the job complete does not prevent the machinists from erroneously logging time against the job through MES. The only way to prevent them from accessing the job through MES is to unrelease it. We assign job numbers based on the SO, Line & Release so we have a lot of job numbers that are similar ie: 16003-1-1, 16003-2-1, 16003-2-2, 16003-3-1 and wanted to make sure that the machinists could not log time on a complete job.
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> Of Virginia
> account.
> costs.
> WIP.
> Any ideas?
> Virginia Joseph
> IT Director
> 440-543-8157
Are those specific orders that are not clearing the AR Clearing account credit card sales orders? We have an on going issue not yet even resolved in our version 803.408 where credit card orders do not create the credit transaction to the AR Clearing account. This is a bug in Vantage.
> Any ideas?
> Virginia Joseph
> IT Director
> vjoseph@...
> 440-543-8157
Sorry...duh...of course that is why you are doing it. It has been so
long for me...anyway, do you have estimated costs on your jobs? I may
be off base here but for a made to order environment I think the
variances occur BECAUSE you order directly to the job. If you cost out
a part at $5, but when you bought to the job it was $4.50, then I think
that 50 cents hits the variance as a negative 50 cents.
Could this be it?
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Virginia
Sent: Wednesday, January 13, 2010 11:58 AM
Subject: [Vantage] Re: AR Clearing acct. not being used - shipments show
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
Behalf
> Of Virginia
as
this
was
problem
jobs.
408,
clearing
> account.
appropriate
above.
as
transaction
manufactured
make
> costs.
confirm
and
expect
WIP.
> WIP.
my
that
> Any ideas?
> Virginia Joseph
> IT Director
> 440-543-8157
Virginia
Make sure that someone as not misinterpreted the quantity bearing
function in the part master and set them to false
If this is set to false no cost transactions are made even when products
are make direct. This should be set to true even when you are
processing non stocked parts
Gary Parfrey
Of Virginia
Sent: 13 January 2010 5:58 PM
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
Behalf
> Of Virginia
as
this
was
problem
jobs.
408,
clearing
> account.
appropriate
above.
as
transaction
manufactured
make
> costs.
confirm
and
expect
WIP.
> WIP.
my
that
> Any ideas?
> Virginia Joseph
> IT Director
> 440-543-8157
No, we don't have estimated costs on our parts. But you might be onto something! I'll have to test it but here's my theory:
I know all our parts are set-up with a Std. costing method and all our parts have no estimated costs
In company config., Production, Job, the "Direct Ship Standard Cost Job Variances" has the "Post to Cost of Sales" radial button selected.
So, the system thinks the entire job cost is the variance and is sending it to COS according to the company settings.
I was assuming that since the release on the SO is marked "Make Direct" Vantage would ignore the part costing and therefore no MFG-VAR transactions would be created. (This is what we saw in 6.1)
We also process a lot of orders that we do not set-up in the part master. So I need to test to confirm that I will get a MFG-CUS transaction for SO/Job that does not reference a part from the part master and the MFG-VAR transactions result from SO/Jobs that use a part from the part master.
THANKS!
Virginia Joseph
vjoseph@...
440-543-8157
> Could this be it?
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> Of Virginia
> > M. Manasa Reddy
> > manasa@ <mailto:manasa@>
> > 800.852.2325
> > 630.806.2000 ofc
> > 630.806.2001 fax
> > www.weldcoa.com
> Behalf
> > Of Virginia
> as
> this
> was
> problem
> jobs.
> 408,
> clearing
> > account.
> appropriate
> above.
> as
> transaction
> manufactured
> make
> > costs.
> confirm
> and
> expect
> WIP.
> > WIP.
> my
> that
> > Any ideas?
> > Virginia Joseph
> > IT Director
> > vjoseph@ <mailto:vjoseph%40deephole.com>
> > 440-543-8157
Virginia
They changed the part costing on ship direct items in Vantage 8.0.
Vantage 6.1 ignored parts which were set as std cost for make direct and
always treated them as actual, but in Vantage 8.0 onwards it variances
against the standard cost when you ship directly. All your non stock
items need to be set to average
Gary
Of Virginia
Sent: 14 January 2010 12:26 AM
THANKS!
Virginia Joseph
440-543-8157
think
> Could this be it?
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
Behalf
> Of Virginia
show
through
16003-1-1,
> > M. Manasa Reddy
> > 800.852.2325
> > 630.806.2000 ofc
> > 630.806.2001 fax
> > www.weldcoa.com
> Behalf
> > Of Virginia
> as
> this
> was
> problem
> jobs.
> 408,
don't
> clearing
> > account.
the
> appropriate
transaction
> above.
showing
> as
> transaction
> manufactured
> make
> > costs.
and
> confirm
job
correct
> and
> expect
> WIP.
> > WIP.
> my
> that
> > Any ideas?
> > Virginia Joseph
> > IT Director
> > 440-543-8157
I also think the VERY fact that you are Standard cost that this will
always happen. I'm so used to average costing that I really cannot talk
about how to prevent the MFG-VAR transactions from happening (if you can
avoid at all).
Good luck!
Manasa
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Virginia
Sent: Wednesday, January 13, 2010 6:26 PM
THANKS!
Virginia Joseph
440-543-8157
think
> Could this be it?
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
Behalf
> Of Virginia
show
through
16003-1-1,
> > M. Manasa Reddy
> > 800.852.2325
> > 630.806.2000 ofc
> > 630.806.2001 fax
> > www.weldcoa.com
> Behalf
> > Of Virginia
> as
> this
> was
> problem
> jobs.
> 408,
don't
> clearing
> > account.
the
> appropriate
transaction
> above.
showing
> as
> transaction
> manufactured
> make
> > costs.
and
> confirm
job
correct
> and
> expect
> WIP.
> > WIP.
> my
> that
> > Any ideas?
> > Virginia Joseph
> > IT Director
> > 440-543-8157
