AR Invoice Post form customization
I have successfully customized the AR Entry Action->Post form which is actually a Epicor.Mfg.UIProc.ARInvoicePost form. I made the customization name the same name as an existing customization on the ARInvoiceEntry form. I can run the customization successfully in developer mode but when I click Action->Post in non Developer mode, it does not run the customized version.
What am I missing?
Please help.
Richard
Look in menu maintenance for the process menu item for the action. In my system that is PR00117. In developer mode it should show in a dialog when the action is done. You need to add the customization to that menu and restart to reload the menu.
Assuming that works in dev then add that menu to your solution.
