We have our process documents attached to each pertinent part in Vantage. When converting from Vantage 8.03 to Epicor 10, is there a way to maintain these document attachments or do they have to be refreshed individually?
@judyh001 If you are going thru all of the stages with Epicor up to 905.702A then to 10.X they should come with, but as @SteveFossey stated you can reattach them via DMT.
Are you using Epicor Upgrade services? They can advise on what is the simplest way to run the process. I think they have a three pass process for around 6,500 US and a round doesn’t count until it is successful.
