The Vantage Gateway and Labor Collector was written so that you could use TT5 terminals for floor data collection. The Gateway is the application that communicates with the TIMB which the TT5's are connected to. It takes the data from these and populates the VTRAN.DBF file with the transactions. The Labor Collector is the second part of this. It reads and monitors the VTRAN.DBF file and processes the records into Vantage Labor. (Although the TT5's are no longer supported in Vantage 8.0)
The Gateway and Labor Collector are a seperate install from Vantage 6.1 CD. Look at the options buttons available on the CD.
The Vantage Help has a good section explaining the structure of the VTRAN.DBF table and records.
So what you can do is install the two programs. All you need to do then is write an application to populate the VTRAN.DBF file and run the Labor Collector. It does work very well.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of marinoni85
Sent: Monday, December 12, 2005 4:57 PM
Subject: [Vantage] Re: Automatic Clock-out in Labor entry? (6.1)
Michael,
What is the Vantage Gateway and how do you access it?
Chris
--- In vantage@yahoogroups.com, "Podlin, Michael"
<michael.podlin@v...> wrote:
then creates a CO record for each in the VTRAN.DBF file which the
Labor Collector will process in Vantage.
Yahoo! Groups Links
Of marinoni85
Michael,
Chris
>need to create a program that reads all the Active LaborHed entries,
> This could be done using the Vantage Gateway setup. You would
>Behalf
> Of marinoni85Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> Sent: Friday, December 09, 2005 10:26 AM
> Carol,
> Did have any luck finding a program that will clock users out
> automatically? I would be interested if you have.
> Thank you,
> Chris Crosta
> --- In vantage@yahoogroups.com, Carol Engen <cengen@w...> wrote:
> > Is it possible to create a program that will automatically clock
> out all
> > employees at 2:00 am?
> > Thank you,
> > Carol Engen
> > Winona Lighting
> > Phone: 507-454-5113, Ext 314
> > Fax: 507-454-4806
> > e-mail: <mailto:cengen@w...> cengen@w...
Yahoo! Groups Links
