Also might want to check the AT command to ensure the filename is
correct and it will run your batch file every night.
Butch
Of Brandon Murch
Sent: Wednesday, August 10, 2005 7:30 AM
Subject: RE: [Vantage] backups
Change the drive letter E: to whatever drive you have Progress installed
on. Change the CD statement to whatever directory Progress is installed
in. Change the path(s) after the probkup online command to whatever
directory your Vantage database is installed.
e:
cd \epic52\progress\bin\
probkup online e:\epic52\sundance\db\sundance e:\backup\sundance.bk
Simply cut and paste into notepad, make changes above, and save as .bat
file
Hope this helps,
Brandon R Murch
Supervisor of Information Technology
WindStone Medical Packaging
406.259.6387
bmurch@... <mailto:bmurch@...>
Sent: Wednesday, August 10, 2005 7:34 AM
Subject: [Vantage] backups
Help...We haven't had a good back up since June 28th.
We were backing up Vantage using a .bat file which create a folder and
stored the backup in that folder, then at the end of each day our tape
backup would backup the backup folder. Unfortunately our .bat file has
some how been deleted and we are no longer backing up Vantage. Does
anyone have a .bat file they can send me or do you have a different
method of backing up everyday?
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
513-831-3211 ext 400
513-831-1209 fax
www.ColdJet.com
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
YAHOO! GROUPS LINKS
Butch
Of Brandon Murch
e:
file
Hope this helps,
Brandon R Murch
406.259.6387
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
_____
YAHOO! GROUPS LINKS
_____
YAHOO! GROUPS LINKS
