Backup solution
Thank you for all your input. I really like the idea of backing up the
system multiple time a day.
Again thanks for the ideas
Sent: Friday, September 28, 2001 10:03 AM
Subject: RE: [Vantage] backup solution
I found the following for ver5.0:
The vantage files vntgbkup with extensions txt-bat and the backvan.bat files
are under the vantage directory. Yet, these files call programs that are
located in the progress and progress\bin directories (_mprshut.exe). Rather
to include paths, I moved the files to the Progress directory and now they
work fine....and don't forget to restore your databases to complete the
process.
You can schedule the routine to run 3 or 4 times a day. I am creating a
batch file to copy these four files under a different name so I could
restore the database at different times of the day and loose only a few
hours rather than a whole day of work....
Mario Aguirre
Lakin General
Sent: Friday, September 28, 2001 6:48 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] backup solution
Good Morning,
I have to redo my backup solution for Vantage 5.00. I looked on the site
and it give documentation for ver.3 and 4. Is the procedure the same for
Version 5. And has anyone found any bugs in the vntgbkup program.
Jason Ford
Pride Signs
Cambridge ON.
www.pridesigns.com
jford@...
519-220-0505
Good Morning,
Jason Ford
Pride Signs
Cambridge ON.
www.pridesigns.com
jford@...
519-220-0505
Backup is identical in 5.0. You just have to take into account the new directories and the database name (vantage.db).
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Friday, September 28, 2001 7:48 AM
Good Morning,
Jason Ford
Pride Signs
Cambridge ON.
www.pridesigns.com
jford@...
519-220-0505
Yahoo! Groups Sponsor
ADVERTISEMENT
process.
Mario Aguirre
Lakin General
Good Morning,
Jason Ford
Pride Signs
Cambridge ON.
www.pridesigns.com
jford@...
519-220-0505
I wanted to simplify the backup routine that was provided. For what its
worth, here is the backup batch file I wrote for our system (we have Vantage
and Progress installed on drive E:). I wrote it to be independent of the
environment settings, so it doesn't matter what you DLC variable is set for.
This keeps the previous three backups available (we backup three times a
day) in directory c:\backup. There is a separate batch file which then
copies the newest backup to another server (in case we lose the whole
Vantage server).
echo on
rem *** Bump old backup files and create a new one.
if exist c:\backup\backup.3 del c:\backup\backup.3
if exist c:\backup\backup.2 ren c:\backup\backup.2 backup.3
if exist c:\backup\backup.2 del c:\backup\backup.2
if exist c:\backup\backup.1 ren c:\backup\backup.1 backup.2
e:
cd \epicor\progress\bin
probkup online e:\epicor\vantage\db\vantage.db c:\backup\backup.1
exit
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
> on the site
> the same for
> Version 5. And has anyone found any bugs in the vntgbkup program..
