BAM Procedure
Rich,
This is great. Thanks.
Regards,
Scott
Sent: Thursday, January 26, 2006 8:50 AM
Subject: RE: [Vantage] BAM Procedure
Arron,
Here is the complete code, I used Mike's method and it worked. The pop
up message here is just text. You can also use this
STRING(Vendor.Character01)SKIP and it will display the value of the data
field.
Hope this answers you question.
{ud/GlbAlert.i &tablename = "OrderHed" }
IF OrderHed.Character02 = "" and (OrderHed.ShipViaCode = "UPST"
or OrderHed.ShipViaCode = "UP3T"
or OrderHed.ShipViaCode = "U2TP"
or OrderHed.ShipViaCode = "UPG"
or OrderHed.ShipViaCode = "UNST"
or OrderHed.ShipViaCode = "NDAT"
or OrderHed.ShipViaCode = "NDAM"
or OrderHed.ShipViaCode = "FXPT"
or OrderHed.ShipViaCode = "FNDA"
or OrderHed.ShipViaCode = "FDXT"
or OrderHed.ShipViaCode = "F2TP"
or OrderHed.ShipViaCode = "FDTP"
or OrderHed.ShipViaCode = "FEDT"
or OrderHed.ShipViaCode = "FDTT")
THEN DO:
MESSAGE STRING("") SKIP
STRING("PLEASE USE THE")SKIP
STRING("VB FORM TO INPUT")SKIP
STRING("THE CUSTOMER'S")SKIP
STRING("THIRD PARTY SHIPPING NUMBER")SKIP
VIEW-AS ALERT-BOX INFO
TITLE "VANTAGE ALERT".
END.
ELSE DO:
Return "Cancel Send":U.
END.
Sent: Thursday, January 26, 2006 8:37 AM
Rich,
I how exactly did you get the pop-up box? Can you use it to request
information? Do you need provision? I have had some difficulty getting
this function to work for me. Any assistance would be appreciated.
PS. an alternative to the Method Mike gave (either will work just fine)
is
to declare a variable and test against that keeping any items that need
changing over time to one area (where you declare you variables), for
instance...
DEFINE VARIABLE shipcode AS CHARACTER INITIAL "UPST,ABCD,WXYZ" NO-UNDO.
IF LOOKUP (OrderHed.ShipViaCode, shipcode) > 0 AND OrderHed.Character01
THEN DO:
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of RICH WAGNER
Sent: Wednesday, January 25, 2006 5:12 PM
Subject: [Vantage] BAM Procedure
I am trying to write an alert that will pop up a box when we enter a
sales order with a ShipVia that requires a third party shipper number
and the character01 field is blank. I have it working with one of our
ShipVia using the statement below, but would like to add other
ShipViacodes and do not know the correct syntax in progress. Can anyone
help, Thanks
IF OrderHed.Character01 = "" and OrderHed.ShipViaCode = "UPST"
Rich Wagner
BAW Plastics
Phone: (412)384-3100
E-Mail: rwagner@...
help, Thanks
Rich Wagner
BAW Plastics
E-Mail: rwagner@...
This should work:
IF OrderHed.Character01 = "" and (OrderHed.ShipViaCode = "UPST"
or OrderHed.ShipViaCode = "XXX"
or OrderHed.ShipViaCode = "YYY"
or OrderHed.ShipViaCode = "ETC") then do:
end.
Of RICH WAGNER
Sent: Wednesday, January 25, 2006 4:12 PM
help, Thanks
Rich Wagner
BAW Plastics
E-Mail: rwagner@...
Rich,
PS. an alternative to the Method Mike gave (either will work just fine) is
instance...
IF LOOKUP (OrderHed.ShipViaCode, shipcode) > 0 AND OrderHed.Character01 = ""
THEN DO:
Aaron Hoyt
Vantage Plastics
Of RICH WAGNER
help, Thanks
Rich Wagner
BAW Plastics
E-Mail: rwagner@...
Yahoo! Groups Links
Aaron,
OK, perhaps this is my turn to help you for a change! I'm not sure if
you're looking for general information on setting up pop-up messages or on
making them interactive (i.e. prompt for and accept input). If it is the
former, see below. If it is the latter, my turn must wait!
Here is the code that I use to remind job planners to schedule jobs...
/* This pop-up message is triggered when a job is released without a
scheduled finish date */
{ud/GlbAlert.i &TableName = "JobHead"}
IF JobHead.JobReleased = Yes AND JobHead.DueDate = ? THEN DO:
message "Job " + (JobHead.JobNum) + " does not have a scheduled finish date.
The job scheduling function should be run for this job." VIEW-AS ALERT-BOX
warning buttons ok.
END.
Return.
HTH.
Regards,
Scott Lepley
Systems Administrator
Mauell Corporation
Phone: 717-432-8686, ext. 14
Fax: 717-432-8688
Email: sal@...
Vantage version: 6.10.532
Rich,
instance...
THEN DO:
Aaron Hoyt
Vantage Plastics
Of RICH WAGNER
help, Thanks
Rich Wagner
BAW Plastics
E-Mail: rwagner@...
Arron,
field.
THEN DO:
END.
ELSE DO:
END.
_____
Rich,
is
instance...
THEN DO:
Aaron Hoyt
Vantage Plastics
Of RICH WAGNER
help, Thanks
Rich Wagner
BAW Plastics
E-Mail: rwagner@...
have
and
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
