I would like to add a Calculated Field to a BAQ I’m developing, and in that field I’m trying to conditionally select PartPlant.PersonID only when JobHead.PersonID is null, otherwise just select JobHead.PersonID.
This is the code from the calculated field: (case when (JobHead.PersonID = ‘’) then (PartPlant.PersonID) else (JobHead.PersonID) end)
However, when I use that code, it just selects JobHead.PersonID for all rows. I’ve already tried writing the when as JobHead.PersonID = null, and that didn’t work either. Syntax Checker says it’s OK as well.
I would really appreciate your feedback!
Chris
