Hello,
Where is the default output location for “BAQ Export Process”?
We are cloud based.
Hello,
We are cloud based.
I think you want to use the Server File Download form to define that.
Can you elaborate?
From what I have read, exported files from “BAQ Export Process” should be saved in an “Epicordata” folder. However, I have been unable to find this folder’s location.
Select your BAQ and click Submit. Look at the system monitor to see that the report is completed and to see the location it gets saved to. In my case I went to Server File Download, changed the drop down to Company, and my report was in there under my name.
Thank you, Nate. I was able to access the file this way, however I am trying to automate this export process. Is this possible? I have the BAQ export process scheduled to run each night but cannot find the export file.
ServerFileDownload is available via a REST endpoint, so you can still automate the download - especially if the file name is constant.
You will find examples of people here on the list calling endpoints from PowerShell.
BTW, you can skip the entire BAQ Export Process by calling the BAQSvc via REST and directly download the results. Again, examples can be found here on the list.
Thanks, Mark
This is all pretty new to me but my end goal is to bring information into Power BI. Maybe this method is not the easiest or correct to begin with.
I have been struggling with connecting Epicor with Power BI using an Odata source… so I turned to this.
Anonymous does not work so I choose basic, enter my credentials and am prompted with this image:
Here is the URL I am attempting to use:
“https://centralusdtpilot50.epicorsaas.com/SaaS5107Pilot/api/v2/odata/{COMPANY}/BaqSvc/{BAQ}/Data?api-key={API}”
Do you have your api key linked to an access scope?
API Key Maintenance Access Scope Field is blank.
Silly question, but you’ve replaced {COMPANY}, {BAQ}, and {API} with your values?
Yes, of course
Create an access scope, add your BAQ, and then add it to your API Key. See if that fixes it.
Can you get to the BAQ Swagger page and execute your BAQ there?
https://yourhost/instance/apps/resthelp/#/home
Yes, I can access and run the BAQ in the Swagger page.
This did not fix it.
How are you trying to run it? In a browser window or PowerShell?
is the api-key enabled and not expired? Is it your BAQ, if it is someone else BAQ is it shared?
I don’t usually encounter this error often and when I do it is my own doing lol
