BAQ - Group by function
Ive created a BAQ to show the Costs of parts in each delivery.
Select
	[ShipHead].[Plant] as [ShipHead_Plant],
	[ShipHead].[ShipDate] as [ShipHead_ShipDate],
	[OrderDtl].[OrderNum] as [OrderDtl_OrderNum],
	[ShipHead].[ShipStatus] as [ShipHead_ShipStatus],
	[OrderHed].[DocOrderAmt] as [OrderHed_DocOrderAmt]
from Erp.Part as [Part]
inner join Erp.ShipDtl as [ShipDtl] on
	  Part.Company = ShipDtl.Company
	and  Part.PartNum = ShipDtl.PartNum
inner join Erp.ShipHead as [ShipHead] on
	  ShipHead.Company = ShipDtl.Company
	and  ShipHead.PackNum = ShipDtl.PackNum
inner join Erp.OrderDtl as [OrderDtl] on
	  ShipDtl.Company = OrderDtl.Company
	and  ShipDtl.OrderNum = OrderDtl.OrderNum
	and  ShipDtl.OrderLine = OrderDtl.OrderLine
inner join Erp.OrderHed as [OrderHed] on
	  OrderDtl.Company = OrderHed.Company
	and  OrderDtl.OrderNum = OrderHed.OrderNum
group by
	[ShipHead].[Plant],
	[ShipHead].[ShipDate],
	[OrderDtl].[OrderNum],
However I think I need to go a group by clause example in the above, which I have had a go at.
It comes up with a message Severity: Error, Text: Bad SQL statement. Review the server event logs for details. Correlation ID: ce132a39-68a8-4347-9b46-39fb66a2d698
I know I need to use the SUM function, but I’m not sure which ones to include and exclude.
Thank you in advance for any help and support.
You’d want to sum the [OrderHed].[DocOrderAmt] column. I.e., add a calculated field, whose value is:
sum(OrderHed.DocOrderAmt)
This calculated field will be used to replace the [OrderHed].[DocOrderAmt] column.
All the other output columns will need to have the GroupBy checkbox checked.
Good Morning,
I’ve followed the advice, however I’m still having a problem. its still saying TEXT: BAD SQL… does anyone has every more ideas what I could do?
Select
	(Sum(OrderHed_DocOrderAmt)) as [Calculated_TotalAmount]
group by
	[ShipHead].[Plant],
You copied your value with an underscore “OrderHed_DocOrderAmt” in your SUM, change it to “OrderHed.DocOrderAmt”
