Just the TableGuid
Okay I still had some old parameters I didnât delete and once I got rid of them and tested the report it printed data that was filtered by the hard dates I added.
The hard dates in the the subreport objectâs properties? Now set them to use the expression =First(....)
Not sure if you nbeed the BAQReportParameter.Date or the .Option field in there.
Its working! I now have it assigned and filtering according to =First(Fields!Date03.Value, âBAQReportParameterâ)! My whole issue was not passing my parameters the way I should have and making things more convoluted than necessary.
Thanks so much @ckrusen, @cfinley and @josecgomez for your help! I have been stuck for quite sometime on this issue!
