Sounds like you haven't added the BAQReportResult table yet.
It can be complicated to explain without pictures but..here is a general outline of the steps I use.
1.) Verify you are connected to the correct XML file?
- From the Crystal "Field Explorer"
--- Right Click on "Database Fields"
----- Left "Click "Set Datasource Location"
--------- ReportDataSet --> Properties --> File Path? Correct if necessary...
2.) Add the BAQReportResult table
- Database menu item
--- Database Expert
------- Expand the ReportDataSet (if your version of Crystal lists multiple reportdatasets, the "pigtail" indicates which you are connected to)
---------- Move BAQReportResult to "Selected Tables"
-------------- Add Links (if your version doesn't add for you)
Good luck...
--- Database Expert
Good luck...
