Yes, I am trying to run it from the same machine that I wrote the
crystal report on, using the same system DSN. In fact after getting
the error I can go to the ..\mfgsysdata\reports\<uname> directory,
and find the .xml file. Replace the sample data file that is created
by the BAQ report tool with the newly generated file. Open the report
in Crystal, and I get the exact report I am looking for. Just not if
I run it from Vantage.
Craig
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
Craig
wrote:
>work in
> Have you installed the OpenEdge Driver? Does doing a Test Connect
> the Data Source Administrator?Behalf Of
> Scott
> -----Original Message-----
> Craig Weissreally
> Sent: Tuesday, December 02, 2008 8:56 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BAQ Report with ODBC subreport
> Thanks for the response, but that didn't seem to help. What is
> strange, is that even when I fill in the information (server,ODBC
> database,table (greyed out), user, password), it doesn't seem to
> accept it. The prompt just keeps coming back.
> Craig
> --- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@>
> wrote:
> > You need to enter the password in the Registry Key
> > HKLM\Software\ODBC\ODBC.INI\{Vantage Entry}
> > Enter a String Value called Password. Modify that and enter the
> > Passwordaccess. )
> > Scott
> Behalf Of
> > Craig Weiss
> > Sent: Monday, December 01, 2008 4:00 PM
> > Subject: [Vantage] BAQ Report with ODBC subreport
> > Is there any trick to creating a Crystal Report using the BAQ
> Report
> > tool, and adding subreports that are using ODBC? I have several
> Crystal
> > Reports that I have written using only ODBC, and when I run them
> from
> > the Vantage menu it gives the option to use the default
> credentials,
> > and all works fine. However, when I add a BAQ Report to the menu
> that
> > contains an ODBC sub-report it asks for credentials, and won't
> accept
> > them even if I type them. Am I missing something?
> > Thanks,
> > Craig
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have
> > already linked your email address to a yahoo id to enable
> > (1) To access the Files Section of our Yahoo!Group for Reportmust have
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> already linked your email address to a yahoo id to enable access. )Builder and
