Does it it work fine if the user supply the proper psw ?
If so, then the solution should be in the Windows Registry.
--- In vantage@yahoogroups.com, "kfmonico" <kfmonico@...> wrote:
> I have an issue with version 6.1, Crystal 8.5. I modified several
of
> the standard reports, such as quoting, to bring in data from the
system
> using ODBC. I used subreports and never had a problem getting this
to
> work properly. Now, however, we are transfering to new servers
using a
> Citrix like system (2X). I can load the reports in Crystal, tell
it
> where the ODBC files and dbf files are located, verify the
database,
> and can view the reports. However, the system always asks for the
ODBC
> password. When I try and view the reports from Vantage, the system
> will not ask for the ODBC password and when it trys to load the
report
> I get a 599 error. My current system never asked for the ODBC
password
> and works fine. Going back to the new system, if I remove the
> subreport, the report works without any issues, so I am sure it is
a
> problem with the ODBC subreports. Is there someway to set up the
ODBC
> driver to ask for the password? Or, better yet to work the way it
> works now on my old system to work without a password? I would
> appreciate any help if someone ran into this before.
