BAQ: Summary Tables in E9
I have JobHead < JobOper
I am displaying JobHead.JobNum, JobOper.JobNum and JobOper.OprSeq
I have chosen First on JobOper.
This works fine.
However, if I add a criteria on JobOper for OpComplete = FALSE, the results are
not accurate.
At first glance they are but after a while you find that SOME are displaying the
incorrect info.
They might display e.g. OprSeq 60 when the first one that isnt complete is
OprSeq 30.
Sent: Wed, 9 March, 2011 13:43:22
Subject: Re: [Vantage] BAQ: Summary Tables in E9
Can you give us an example of when it works/doesn't?
How is it not working? Are the total wrong?
On Wed, Mar 9, 2011 at 4:18 AM, Chris Thompson <chriselectrix@...>wrote:
> Hi
> Upon further checking, it doesnt work fully.
> It works with some but not with others.
> Any suggestions?
> Thanks.
> From: Waffqle <waffqle@...>
> Sent: Tue, 8 March, 2011 16:22:08
> Set it as first, and sort it. That should do the trick.
> On Tue, Mar 8, 2011 at 10:51 AM, Chris Thompson <chriselectrix@...
> >wrote:
> > I've tried that but it didnt seem to work.
> > Do you mean set up the JobOper table as 'First'?
> > Sent: Tue, 8 March, 2011 15:48:36
> > Under "Display > Sort Order" on the BAQ designer.
> > Set the JobOper table to sort by OprSeq and only retrieve the first
> record.
> > On Tue, Mar 8, 2011 at 10:29 AM, Chris Thompson <chriselectrix@...
> > >wrote:
> > > I already indirectly knew how to do that.
> > > Here's one for you -
> > > I have JobHead < JobOper.
> > > I want to see the next operation (JobOper.OprSeq) for each job that
> isnt
> > > complete.
> > > I.e. Job 45667 - operation 10, 20, 30, 40 are marked as complete.
> > Operation
> > > 50,
> > > 60, 70, 80, 90, 100 still remain.
> > > However I only want to see Job 45667 Operation 50 in the results of my
> > BAQ
> > > - I
> > > dont want to see 60 etc.
> > > I have tried using First on the join but it doesnt work like that as
> the
> > > operations might not necessarily follow on when the jobs were created.
> > > ie 45 might have been inserted between operation 40 and 50 after the
> > > BOM/Job was
> > > created, therefore 45 actually shows up at the end when the table is
> > > imported
> > > un-sorted.
> > > Any suggestion would be appreciated.
> > > Is there any kind of formula I can use to only show the next operation
> > that
> > > hasnt been complete?
> > > something like
> > > if joboper.oprseq = 40 and joboper.opcomplete = true then show next
> > oprseq?
> > > Thanks.
> > > Sent: Tue, 8 March, 2011 14:14:29
> > > You got it.
> > > average(OrderHed.OrderNum)
> > > You still need to add the table to the report, just don't use any of
> the
> > > fields directly.
> > > On Tue, Mar 8, 2011 at 9:09 AM, Chris Thompson <
> chriselectrix@...
> > > >wrote:
> > > > So how does it know which table to summarise? Or is 'x' replaced by
> the
> > > > field
> > > > name?
> > > > Sent: Tue, 8 March, 2011 13:11:41
> > > > The UI will give you a tree where you can choose the functions you
> > like.
> > > > Put
> > > > the format is:
> > > > average(x)
> > > > count(x)
> > > > etc.
> > > > On Tue, Mar 8, 2011 at 5:21 AM, Chris Thompson <
> > chriselectrix@...
> > > > >wrote:
> > > > > So what would the calculated field look like?
> > > > > Sent: Mon, 7 March, 2011 20:04:29
> > > > > Just add the table to the BAQ and create calculated fields without
> > > > setting
> > > > > any of the normal fields to display. As far as I've seen, this
> > provides
> > > > the
> > > > > same functionality.
> > > > > On Mon, Mar 7, 2011 at 1:40 PM, Joe Rojas <jrojas@...>
> > wrote:
> > > > > > Hello,
> > > > > > I noticed that the checkbox to make a table a summary table, in
> the
> > > BAQ
> > > > > > Designer, is not available in E9 as it was in V8.
> > > > > > How do you create a summary table or simulate this feature in E9?
> > > > > > Joe Rojas | Director of Information Technology | Mats Inc
> > > > > > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > > > > > jrojas@... | www.matsinc.com Ask us about our clean,
> green
> > > and
> > > > > > beautiful matting and flooring
> > > > > > This message is intended only for the individual named. If you
> are
> > > not
> > > > > the
> > > > > > named addressee you should not disseminate, distribute or copy
> this
> > > > > e-mail.
> > > > > > Please notify the sender immediately by e-mail if you have
> received
> > > > this
> > > > > > e-mail by mistake. Please note that any views or opinions
> presented
> > > in
> > > > > this
> > > > > > email are solely those of the author and do not necessarily
> > represent
> > > > > those
> > > > > > of the company.
> > > > > > [Non-text portions of this message have been removed]
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You
> > must
> > > > have
> > > > > already linked your email address to a yahoo id to enable access. )
> > > > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder
> > > and
> > > > > Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> must
> > > have
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> > have
> and
> have
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
http://groups.yahoo.com/group/vantage/files/.%c2%a0
Hello,
I noticed that the checkbox to make a table a summary table, in the BAQ
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Just add the table to the BAQ and create calculated fields without setting
any of the normal fields to display. As far as I've seen, this provides the
same functionality.
On Mon, Mar 7, 2011 at 1:40 PM, Joe Rojas <jrojas@...> wrote:
> Hello,
> of the company.
Joe, that has completely changed. Here is the answer from Epicor answer book
Â
Summary:Â Â Â Â Â Â Â BAQ How to set the summarized field in a BAQ on Epicor 9
Book:Â Â Â Â Â Â Â Â Â Support Solutions
Page:Â Â Â Â Â Â Â Â Â 8781ESC
PAGE
8781ESC
SUMMARY:
How to set the summarized field in a BAQ on Epicor 9.Â
DESCRIPTION:
The Summarize checkbox used in 8.03.4xx and below is no longer available in
EPicor 9 so how do I summarize a table? In Epicor 9 adding a calculation that
uses a aggregate calculation will cause the system to automatically summarize
your table. Aggregate functions are - Average, Count, and Total.
Example to summarize fields for PODetail
- Go to Systems Management > Utilities > BAQ Designer
- On the Phase Builder sheet drag both the POHeader and then the PODetail to the
grid.
- On Display tab, select fields from POHeader
- Click the calculator icon and create the follow expression
       TOTAL(PODetail.OrderQty * PODetail.UnitCost)
- Save and test your BAQ
You'll find that the PODetail table has been summarized.
VERSION
9.04.5XX
Sent: Mon, March 7, 2011 1:40:22 PM
Subject: [Vantage] BAQ: Summary Tables in E9
Â
Hello,
company.
Thanks Mark (and Waffqle)!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wagner
Sent: Monday, March 07, 2011 3:35 PM
Summary: BAQ How to set the summarized field in a BAQ on Epicor 9
Book: Support Solutions
Page: 8781ESC
PAGE
8781ESC
SUMMARY:
DESCRIPTION:
grid.
VERSION
9.04.5XX
From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> >
Hello,
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about our clean, green and beautiful
company.
same functionality.
> Hello,
> of the company.
The UI will give you a tree where you can choose the functions you like. Put
the format is:
average(x)
count(x)
etc.
> same functionality.
> > Hello,
> the
> e-mail.
> this
> those
> > of the company.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
So how does it know which table to summarise? Or is 'x' replaced by the field
name?
the format is:
average(x)
count(x)
etc.
> same functionality.
> > Hello,
> the
> e-mail.
> this
> those
> > of the company.
You got it.
You still need to add the table to the report, just don't use any of the
fields directly.
> field
> name?
> Put
> the format is:
> average(x)
> count(x)
> etc.
> setting
> the
> > same functionality.
> > > Hello,
> > the
> > e-mail.
> this
> > this
> > those
> > > of the company.
> have
I want to see the next operation (JobOper.OprSeq) for each job that isnt
complete.
I.e. Job 45667 - operation 10, 20, 30, 40 are marked as complete. Operation 50,
However I only want to see Job 45667 Operation 50 in the results of my BAQ - I
I have tried using First on the join but it doesnt work like that as the
ie 45 might have been inserted between operation 40 and 50 after the BOM/Job was
created, therefore 45 actually shows up at the end when the table is imported
un-sorted.
Is there any kind of formula I can use to only show the next operation that
something like
if joboper.oprseq = 40 and joboper.opcomplete = true then show next oprseq?
Thanks.
You got it.
fields directly.
> field
> name?
> Put
> the format is:
> average(x)
> count(x)
> etc.
> setting
> the
> > same functionality.
> > > Hello,
> > the
> > e-mail.
> this
> > this
> > those
> > > of the company.
> have
Set the JobOper table to sort by OprSeq and only retrieve the first record.
> complete.
> 50,
> - I
> BOM/Job was
> imported
> un-sorted.
> something like
> Thanks.
> You got it.
> fields directly.
> > field
> > name?
> > Put
> > the format is:
> > average(x)
> > count(x)
> > etc.
> > setting
> > the
> > > same functionality.
> > > > Hello,
> BAQ
> and
> not
> > > the
> > > e-mail.
> > this
> in
> > > this
> > > those
> > > > of the company.
> > have
> and
> have
> complete.
> 50,
> - I
> BOM/Job was
> imported
> un-sorted.
> something like
> Thanks.
> You got it.
> fields directly.
> > field
> > name?
> > Put
> > the format is:
> > average(x)
> > count(x)
> > etc.
> > setting
> > the
> > > same functionality.
> > > > Hello,
> BAQ
> and
> not
> > > the
> > > e-mail.
> > this
> in
> > > this
> > > those
> > > > of the company.
> > have
> and
> have
> > complete.
> Operation
> > 50,
> BAQ
> > - I
> > BOM/Job was
> > imported
> > un-sorted.
> that
> > something like
> oprseq?
> > Thanks.
> > You got it.
> > fields directly.
> > > field
> > > name?
> like.
> > > Put
> > > the format is:
> > > average(x)
> > > count(x)
> > > etc.
> chriselectrix@...
> > > setting
> provides
> > > the
> > > > same functionality.
> wrote:
> > > > > Hello,
> > BAQ
> > and
> > not
> > > > the
> > > > e-mail.
> > > this
> > in
> > > > this
> represent
> > > > those
> > > > > of the company.
> must
> > > have
> > and
> > have
> and
> have
That seems to work.
Thanks.
> > complete.
> Operation
> > 50,
> BAQ
> > - I
> > BOM/Job was
> > imported
> > un-sorted.
> that
> > something like
> oprseq?
> > Thanks.
> > You got it.
> > fields directly.
> > > field
> > > name?
> like.
> > > Put
> > > the format is:
> > > average(x)
> > > count(x)
> > > etc.
> chriselectrix@...
> > > setting
> provides
> > > the
> > > > same functionality.
> wrote:
> > > > > Hello,
> > BAQ
> > and
> > not
> > > > the
> > > > e-mail.
> > > this
> > in
> > > > this
> represent
> > > > those
> > > > > of the company.
> must
> > > have
> > and
> > have
> and
> have
Hi
Any suggestions?
Thanks.
> > complete.
> Operation
> > 50,
> BAQ
> > - I
> > BOM/Job was
> > imported
> > un-sorted.
> that
> > something like
> oprseq?
> > Thanks.
> > You got it.
> > fields directly.
> > > field
> > > name?
> like.
> > > Put
> > > the format is:
> > > average(x)
> > > count(x)
> > > etc.
> chriselectrix@...
> > > setting
> provides
> > > the
> > > > same functionality.
> wrote:
> > > > > Hello,
> > BAQ
> > and
> > not
> > > > the
> > > > e-mail.
> > > this
> > in
> > > > this
> represent
> > > > those
> > > > > of the company.
> must
> > > have
> > and
> > have
> and
> have
> Hi
> Any suggestions?
> Thanks.
> record.
> isnt
> > > complete.
> > Operation
> > > 50,
> > BAQ
> > > - I
> the
> > > BOM/Job was
> > > imported
> > > un-sorted.
> > that
> > > something like
> > oprseq?
> > > Thanks.
> > > You got it.
> the
> > > fields directly.
> chriselectrix@...
> the
> > > > field
> > > > name?
> > like.
> > > > Put
> > > > the format is:
> > > > average(x)
> > > > count(x)
> > > > etc.
> > chriselectrix@...
> > > > setting
> > provides
> > > > the
> > > > > same functionality.
> > wrote:
> > > > > > Hello,
> the
> > > BAQ
> green
> > > and
> are
> > > not
> > > > > the
> this
> > > > > e-mail.
> received
> > > > this
> presented
> > > in
> > > > > this
> > represent
> > > > > those
> > > > > > of the company.
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
