I would check first - For that amount of info, I think 3 of 9 will work the same
as 128 and they should be able to scan 3 of 9 if only 128 in enabled on their
scanners (even though it is unlikely to only enable 128). Every scanner I have
ever used scan 3 of 9 and 128 by default.
Sent: Wed, 1 June, 2011 17:29:26
Subject: [Vantage] Re: Bar Codes on Packing Slips
Â
Gotcha. OK, they are definitely separate fields and would be separate scans. I
was able to locate the DataWorks Bar 39 font, but it looks like we're gonnaa
need to purchase a Code 128 font.
Â
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi Lauren
> Have you got something like this?
> "*" & ToText({JobHead.JobNum}) & "$I" & "*"
> The * need to be in " " and needs to be followed by a &
> If you send me your formula I will have a look.
> Thanks.
> From: "Hellings, Lauren" <lauren.hellings@...>
> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> Sent: Wed, 1 June, 2011 15:15:57
> Subject: RE: [Vantage] Re: Bar Codes on Packing Slips
> ÂÂ
> What exactly needs to go in the formula field? I am trying to create a barcode
> for a different form. I have the formula field created and I have changed the
> font to the DataWorks Bar 39, but I get an error in the formula using a *
>before
> and after the field that I have selected.
> Can someone please send an example?
> Thank you,
> Lauren Hellings
> Business Analyst
> Cell: 832-472-1736
> Fax: 281-207-0672
> email: lauren.hellings@...<mailto:lauren.hellings@...>
> www.c-p-i.com<http://www.c-p-i.com/>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Chris Thompson
> Sent: Wednesday, June 01, 2011 7:59 AM
> Subject: Re: [Vantage] Re: Bar Codes on Packing Slips
> If you are wanting to create barcodes in Crystal it is fairly easy
> You need to create a formula with the data you require then add to your report.
> Then change the new field font to DataWorks 3 of 9.
> You always need a * at the beginning and end of a typical linear barcode ( like
> you see in the supermarket ).
> I would recommend enabling full ascii on the barcode guns.
> Then you can use special characters in your barcode to act like a space,
> carriage return, tab etc without typing them in text (as the barcode font wont
> like this and it will show as a gap in the barcode).
> If you want to move to PDF 417 (2D barcodes you can do much more).
> Let me know if you need an example.
> Did you want to see all of that data in one barcode, if so it may be too long
> for a 3 of 9 barcode.
> What separator would you use if it was all in one string?
> From: Brian Roberts <broberts@...<mailto:broberts%40gfxltd.com>>
> Sent: Wed, 1 June, 2011 13:29:12
> If you're brand new to barcode fonts...
> The most common barcode is called "3 of 9", and you'll often see it abbreviated
> "39". Its font file is available several places, including as part of Vantage.
> Install in Windows folder as suggested below, or use Control Panel -> Fonts ->
> Install New Font.
> Experiment in Word/your favourite word processor... type *123456* (the star
> before and after is required) then change the font to your barcode font, then
> print and scan to test. Doing this in a Crystal report is just (a) create a new
> field with a formula of (eg) the PO number with stars before & after and (b)
> change the font on that new field.
> You mention making a barcode for line#... many scanners won't scan very short
> barcodes like *1* by default - look for a scanner setting called "any length".
> Spaces in barcodes can be a headache as well.
> Brian.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> Sean
> Toler
> Sent: Wednesday, June 01, 2011 7:21 AM
> Ok, thanks.
> Actually no, I'm not sure how to add these to the Crystal Report yet. I was
> hoping it would make itself evident once I reached that step. The data that
>will
> need to be barcoded is:
> PO Number; Release #; Line #; Part Number; Revision; and Quantity.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> , Chris
> Thompson <chriselectrix@<mailto:chriselectrix@>> wrote:
> > You need to run a search on the server that has Vantage/Epicor installed for
> > "DataWorks Bar 39".
> > You need to copy this into the client c:\windows\fonts folder.
> > Do you know how to add these to the Crystal Report?
> > What data do you need to be turned into a barcode?
> > Thanks.
> > From: Sean Toler <seantoler@<mailto:seantoler@>>
> > Sent: Tue, 31 May, 2011 20:30:13
> > Â
> > Cool! Now for a stupid question, where exactly would I find that particular
> >file
> > and where would it need to be installed on the clients?
> ><mailto:vantage%40yahoogroups.com> , "Vic
> >Drecchio" <vic.drecchio@> wrote:
> > > The font is included with the Vantage installation. Check the server's
> > > install and look for dwbar.ttf and install it on all of the clients that
> > > will use barcodes.
> ><mailto:vantage%40yahoogroups.com> ] On Behalf
> > > Of Sean Toler
> > > Sent: Tuesday, May 31, 2011 3:15 PM
> > > Subject: [Vantage] Bar Codes on Packing Slips
> > > Hello.
> > > We have a customer who is requiring all of their vendors to start
> > > sending packing slips with bar codes on them. I am trying to find out
> > > how to add bar codes to each line of our existing packing slip in
> > > Crystal Reports (we have CR XI). I am assuming that we would need to
> > > download and install some type of font, but the mystery is from where to
> > > we download the font and into where do we install it.
> > > Any ideas?
> ----------Legal Disclaimer----------
> The information contained in this message may be privileged and confidential,
> and is intended solely for the use of the named addressee. No other person is
> authorized to access, copy or re-use this message (or any information contained
> herein). If you are not the intended recipient, please notify us immediately by
> replying to this message and delete it from your computer.
