Got an odd one here. I can print the exact same report with the same settings in our Live environment and I get a report with scannable barcodes. When I print that same report in Test (I just copied the report style over using Solution Workbench), it prints the text instead of the barcode. Huh? Naturally, I want the barcode to print in our Test environment. Help!
Im assuming your environments are hosted on seperate machines. Its been awhile since i had this problem, but its likely due to the font not being installed on your Test application server or your Test SSRS/sql server. Can’t remember
They are on different machines… I wondered if it might be something like that.
