<div id="ygrps-yiv-1025727395yiv9756070321ygrp-text">
<div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, Sans-Serif;font-size:10px;">Hi<div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3052"><br clear="none"><span></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3168"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3228">Bartender might be outputting Full Ascii but is your scanner set up to read full ascii?</span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3229"><br clear="none"><span></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3230"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3275">PDF417 is font like 3of9 or 128. It is a complex formula that generate the barcode.</span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3274"><br clear="none"><span></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3273"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3467">What happens if you scan the barcode into excel? Does it scan correctly or does it scan the warehouse twice?</span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3471"><br clear="none"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3467"></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3520"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3467">There must be a simple fix somewhere - we have been using the duel field barcodes with Epicor since 2009.</span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3521"><br clear="none"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3467"></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3522"><span id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3467">Thanks<br clear="none"></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3468"><br clear="none"><span></span></div><div id="ygrps-yiv-1025727395yiv9756070321yui_3_16_0_1_1453278203197_3469"><span></span></div> <div class="ygrps-yiv-1025727395yiv9756070321qtdSeparateBR"><br clear="none"><br clear="none"></div><div class="ygrps-yiv-1025727395yiv9756070321yqt3242492413" id="ygrps-yiv-1025727395yiv9756070321yqt27279"><div style="display:block;" class="ygrps-yiv-1025727395yiv9756070321yahoo_quoted"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, Sans-Serif;font-size:10px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, Sans-Serif;font-size:16px;"> <div dir="ltr"><font size="2" face="Arial"> On Tuesday, 19 January 2016, 22:40, "Joshua Giese jgiese@... [vantage]" <vantage@yahoogroups.com> wrote:<br clear="none"></font></div> <br clear="none"><br clear="none"> <div class="ygrps-yiv-1025727395yiv9756070321y_msg_container"><div id="ygrps-yiv-1025727395yiv9756070321"><div>
<div>
Technology Solutions : CTO
Office Phone: 920.437.6400 x342
Sent: Tuesday, January 19, 2016 3:44 PM
Subject: RE: [Vantage] Re: barcodes with embedded tabs, epicor, intermec and excel (or bartender)
Sent: Tuesday, January 19, 2016 3:12 PM
Sent: Tuesday, January 19, 2016 3:00 PM
Subject: [Vantage] Re: barcodes with embedded tabs, epicor, intermec and excel (or bartender)
So, the handhelds are 2D scanners, however we have barcode readers attached to work stations that are only 1D so we will need to stick with 1D on this case. I did try the 2D barcode just to see if it would make a difference, and it does the same thing (same info in both fields)
"The other is to switch to a different barcode "Font" that supports the extended ASCII codes."
With bartender, I am using Code 128 which is full ASCII. It codes in the tab, and the cursor moves like it should so it seems like the scanner is reading full ASCII
yup. That's why I'm here......
Since the phone doesn't have tab function, it puts in a space. Is there anything I should do with that information?
"You may need to turn Full Ascii on on the device."
It's on as far as I can tell. It will read a tab and move, so I'm thinking it has to be on. I just don't know why it's putting in the info from the first part of the barcode in the second field. Like Josh says, maybe it's a timing thing that I can't change.
With the 1D scanners (which up until this point I have pretty much forgot about) I tried using the HH program from epicor on the thin client workstations and there, it will not tab at all. I opened up a text document and scanned as a keyboard wedge and the tab is communicated when writing to a simple text file, but a tab in E-10 encoded into the barcode doesn't seem to work. I tried messing with that 123scan2 program and found a few things link enable keyboard wedge and keystroke delay to 20ms but it didn't change anything with E-10. I'll probably have to do some more work to try to understand how that 123scan2 works.
Looks like I'm stuck using 1 barcode/field unless anyone knows of some obscure setting to change somewhere.
Thanks for your help guys.
</div>
<div class="ygrps-yiv-1025727395yiv9756070321yqt9719856939" id="ygrps-yiv-1025727395yiv9756070321yqt32925"><div style="color:#fff;height:0;"></div></div>
</div>
<div class="ygrps-yiv-1025727395yiv9756070321yqt3242492413" id="ygrps-yiv-1025727395yiv9756070321yqt23388"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mkp #ygrps-yiv-1025727395yiv9756070321hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mkp #ygrps-yiv-1025727395yiv9756070321ads {
margin-bottom:10px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mkp .ygrps-yiv-1025727395yiv9756070321ad {
padding:0 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mkp .ygrps-yiv-1025727395yiv9756070321ad p {
margin:0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mkp .ygrps-yiv-1025727395yiv9756070321ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-sponsor #ygrps-yiv-1025727395yiv9756070321ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-sponsor #ygrps-yiv-1025727395yiv9756070321ygrp-lc #ygrps-yiv-1025727395yiv9756070321hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-sponsor #ygrps-yiv-1025727395yiv9756070321ygrp-lc .ygrps-yiv-1025727395yiv9756070321ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321activity span {
font-weight:700;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321activity span span {
color:#ff7900;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321activity span .ygrps-yiv-1025727395yiv9756070321underline {
text-decoration:underline;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321attach div a {
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321attach label a {
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321bold a {
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 dd.ygrps-yiv-1025727395yiv9756070321last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 dd.ygrps-yiv-1025727395yiv9756070321last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 dd.ygrps-yiv-1025727395yiv9756070321last p span.ygrps-yiv-1025727395yiv9756070321yshortcuts {
margin-right:0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321attach-table div div a {
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321attach-table {
width:400px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321file-title a, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321file-title a:active, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321file-title a:hover, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321file-title a:visited {
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321photo-title a, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321photo-title a:active, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321photo-title a:hover, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div.ygrps-yiv-1025727395yiv9756070321photo-title a:visited {
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 div#ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg #ygrps-yiv-1025727395yiv9756070321ygrp-msg p a span.ygrps-yiv-1025727395yiv9756070321yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321green {
color:#628c2a;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 o {
font-size:0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321photos div {
float:left;width:72px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321reco-category {
font-size:77%;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321reco-desc {
font-size:77%;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 .ygrps-yiv-1025727395yiv9756070321replbq {
margin:4px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg select, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 input, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg pre, #ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 code {
font:115% monospace;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-mlmsg #ygrps-yiv-1025727395yiv9756070321logo {
padding-bottom:10px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-msg p#ygrps-yiv-1025727395yiv9756070321attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-reco #ygrps-yiv-1025727395yiv9756070321reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-sponsor #ygrps-yiv-1025727395yiv9756070321ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-sponsor #ygrps-yiv-1025727395yiv9756070321ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-sponsor #ygrps-yiv-1025727395yiv9756070321ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1025727395 #ygrps-yiv-1025727395yiv9756070321 #ygrps-yiv-1025727395yiv9756070321ygrp-vital ul li:last-child {
border-right:none !important;}
