BOM Revision Change in 8.03
Yes.
In .311, you can copy all methods from an old Part Rev to the new Part Rev you are working on or, in 403 & 404, you can also copy a selected single method under an old Part Rev to a single selected method you are working on.
Carey Ryerson <cryerson@...> wrote:
We are currently using 8.0 and one of the complaints that I have heard
is that when a new revision is created, the BOM must be rebuilt from
scratch. We are moving to 8.03, and I am hoping that we can copy the
components of a rev. A BOM to rev. B and then make the necessary
changes without rebuilding the entire BOM from scratch. Is this
possible?
between 0000-00-00 and 9999-99-99
possible?
Yes, you get the details for any other revision.
> possible?
It's always been possible as far back as I can remember.
When you are in Engineering Workbench and have the new revision checked
out, right click on the part in the tree and select "get details:from
method/job/quote", then choose the part number and revision level you
want to copy the details from.
Amy O'Malley
Process Engineer
Heraeus Medical Components Division
Lino Lakes, Minnesota
amy.omalley@...
Phone: 651-792-8516
Fax: 651-792-8616
Of Carey Ryerson
Sent: Tuesday, April 15, 2008 9:07 AM
Subject: [Vantage] BOM Revision Change in 8.03
possible?
> possible?
Absolutely. You can create a new revision from a previous revision/alt method;
a quote; or a job. This is just as true in 8.03 as it was in 8.0
Mark W.
Carey,
When you "Get Details" you have the option to get from a quote, method
or Job. Method would be ANY revision in the system. To get from a
quote or Job it has to marked as a template (in the Job), or marked
Engineered and Template in the quote to get from a quote.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Carey Ryerson
possible?
