BPM C# code question
Yes, I have it resolved, thanks to Jose who pointed me to a very good document. The design change a little bit. It use Part_UD fields to update OrderDtl and UD field. Here is the code
foreach (var od in ttOrderDtl)
   var pt = (from ptRow in Db.Part
                  where string.Compare(od.Company, ptRow.Company, true) == 0 &&
                             string.Compare(od.PartNum, ptRow.PartNum, true) == 0
                  select ptRow).FirstOrDefault();
   if (pt != null)
      od.SetUDField("SalesRepID1_c",pt.SalesRepID1_c);
      od.SetUDField("SalesRepName1_c",pt.SalesRepName1_c);
      od.RepRate1 = pt.RepRate1_c;
      od.RepSplit1 = pt.RepSplit1_c;
Db.Validate();
Thanks everyone who join the discussion in this topic
I am new to BPM. I am trying to write a method directive on sales order update to execute C# code to perform following tasks:
1. Get the current order number
2. For each order line, using PartNum to lookup Part table
3. Update OrderDtl->ShortChar01 with Part->ShortChar01
I could not find any document about the C# code in BPM.
Could someone give me some advice on how to accomplish this.
Read the E10 Converted Code Programmers Guide in EpicWeb it shows you how to call business objects and such from BPM
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Sep 22, 2015 at 9:23 AM, yzou79@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span>I am new to BPM. I am trying to write a method directive on sales order update to execute C# code to perform following tasks:</span></p><p><span><br></span></p><p><span>1. Get the current order number</span></p><p><span>2. For each order line, using PartNum to lookup Part table</span></p><p><span>3. Update OrderDtl-&gt;ShortChar01 with Part-&gt;ShortChar01</span></p><p><span><br></span></p><p><span>I could not find any document about the C# code in BPM. </span></p><p><span><br></span></p><p><span>Could someone give me some advice on how to accomplish this.</span></p><p><span><br></span></p><p><span>Thanks </span></p><p><span><br></span></p><p><span><br></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Why are you trying to get that information into OrderDtl.ShortChar01 is there a particular use case that doesn’t meet the following?
If it’s for reporting you can always get it from the part through RDD linking.
If it’s for displaying in the screen save yourself a UD field and use a foreign key view.
Joshua Giese
Technology Solutions : CTO
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
Sent: Tuesday, September 22, 2015 8:24 AM
Subject: [Vantage] BPM C# code question
Thanks, Jose. I will read that document.
Thanks, Joshua. I don't know the purpose of this project. I am a developer with limited knowledge about Epicor and was assigned to this task by my boss. I will pass your remark to my boss.
Because I think it’s important enough to stress…
Always try to make sure you understand the why and how it will be used when doing a project so you can make sure you are deploying the “right tool for the job”. A lot of it should be just the enjoyment of solving a problem the most effectively, if a user asks for a textbox added and I just put it out there, and then I found out the textbox is used to "flag" records as "PENDING INVOICE" because the end user doesn't know that Shipped Slips automatically go to the pending invoice queue. That means I've built a "solution" to a non-existent problem.
Joshua Giese
Sent: Tuesday, September 22, 2015 10:07 AM
Subject: [Vantage] Re: BPM C# code question
I think it would be great to answer a question if you are able but, avoid turning questions back on the requester for justification…
Sent: Tuesday, September 22, 2015 11:24 AM
Subject: RE: [Vantage] Re: BPM C# code question
Joshua Giese
[Image removed by sender. http://wcibags.com/email/emailFooter4.jpg%5d<http://www.wcibags.com/>
Joe I totally disagree. Developers/IT need to be far more involved than ever before to ensure agile and efficient solutions are implemented. Blindly being a sheep to the requestor is not good for anyone it’s how bloat and garbage collection happen.
Joshua Giese
Sent: Tuesday, September 22, 2015 10:44 AM
Joshua Giese
[Image removed by sender. http://wcibags.com/email/emailFooter4.jpg]<http://www.wcibags.com/>
Yep, that’s a fair point. I just think sometimes it’s tough for a developer to come here to ask a question only to be challenged for justifications.
Sent: Tuesday, September 22, 2015 12:01 PM
Joshua Giese
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Joshua Giese
[Image removed by sender. http://wcibags.com/email/emailFooter4.jpg%5d<http://www.wcibags.com/<http://wcibags.com/email/emailFooter4.jpg%5d%3chttp:/www.wcibags.com/>>
Lol it wasn’t meant as a justification but exploratory questions for him to implement the best solution.
A wise man once told me “You’re only ever one question away from reality”. Ask someone how they are doing they will say “I’m good you?”, ask more specific questions and you find out they’re a hot mess.
Joshua Giese
Sent: Tuesday, September 22, 2015 11:18 AM
Joshua Giese
Joshua Giese
[Image removed by sender. http://wcibags.com/email/emailFooter4.jpg]<http://www.wcibags.com/<http://wcibags.com/email/emailFooter4.jpg%5d%3chttp:/www.wcibags.com/>>
Joe,
I have to side with Josh here, we are here to help others and sometimes a little kick in the pants its the best help you can give. If he learns why he is doing this project maybe we can then help him find a better solution. Most "clients" don't know what they really need, they know what they think they want. It is our job as developers to figure out the what the end goal is and to find a solution to the real problem.
Jose C Gomez
Software Engineer
On Tue, Sep 22, 2015 at 11:44 AM, Joe Englert englertj@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>I think it would be great to answer a question if you are able but, avoid turning questions back on the requester for justification…
Joshua Giese
</div>
Completely agree on the need to understand the why before even starting to figure out a solution.
Understanding why usually helps build it better and can be expanded if needed.
And the biggest reason to ask why is if they can't explain why they need it very well, very likely they don't need to be doing it.
Something that needs to be asked as part of the why is how does the current system handle what you want and why can't you do it that way?
Jim Kinneman
Encompass Solutions, Inc
Color me outnumbered. ☺ I give people the benefit of the doubt – they’ve already gotten the job, I assume they are professionals who don’t need analysis 101. If they need a general question answered, they’d ask it.
Sent: Tuesday, September 22, 2015 2:39 PM
Jim Kinneman
Have you gotten anywhere with this issue?  I need to do a similar operations.
GreatBeachVacation,
Can you give some more information on what you are needing to do?
