What was the actual email code? I am running into a similar situation where I have everything working except the display of the detail lines. If I just insert the fields, it displays each lines field with semicolons between, then the next piece of data. how would you write the query to display each detail line as a line in the email?
--- In vantage@yahoogroups.com, Miguel Santillan <msantillan@...> wrote:
> Answering my own question...
> In my email template, for the fields that I am pulling, I needed to check off the appropriate filters. Specifically unchanged for the DMRHead information.
> Regards,
> Miguel A. Santillan
> ERP Administrator
> Compass Components, Inc.
> 510-661-6666 Office
> 510-656-0603 Fax
> msantillan@...<mailto:msantillan@...>
> www.ccicms.com<http://www.ccicms.com/>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of miguel_ccicms
> Sent: Tuesday, February 28, 2012 10:35 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] BPM: Debit Memo notification
> There is boiler plate notification for this, but it does not give much information about the DMR. I got the BPM to trigger, used a notify pop-up for this, but I think since this is a POST Process, I cant use the tt data to display in my email. How would I write the query (link the tables) so that I can retrieve the data stored. Or is there a better way to do this.
> DMRProcessing.CustomUpdate Post Processing.
> for each ttDMRActn no-lock where (ttDMRActn.RowMod = 'U' Or ttDMRActn.RowMod = 'A' )And (ttDMRActn.ActionType = 'C' Or ttDMRActn.ActionType = 'D' ) , each ttDMRHead, each ttDMRActn where (ttDMRHead.Company = ttDMRActn.Company and ttDMRHead.DMRNum = ttDMRActn.DMRNum) no-lock
> I am trying to get the value from both DMRHead and DMRActn
> All my data in my email is blank.
> Thanks
